Old 08-25-2008, 12:10 PM
kesparate is on a distinguished road
"winterizing"
so i'll be leaving my current job for greener pastures in a few days and i am the only one who can run the Haas VF3. they are looking for my replacement as i type, but i don't think they're going to have much luck in the short term as the market's pretty tight in WI. i'm still getting calls for interviews and haven't sent any resumes out in three weeks.
so the question is what should i do to the machine so that it can sit with out being run for a potentially extended period without going to wrack and ruin. my current plans are to empty the coolant tank, take everything off the table, clean it thoroughly, and the spray it all down with a rust preventative.
any suggestions?
Old 08-25-2008, 09:42 PM
Check that the Run In program is in the machine; this will be O02021.
Leave instructions that if the machine has not been run for more than three weeks the Run In program should be run, and it is important to periodically check the spindle temperature. If the spindle nose gets warm stop the program, let the machine cool down and restart.
When the machine is not being used the oil drains into the lower spindle bearing and then when it is run at high speed the bearing can get very hot. The Run In program is intended to purge the oil out of the bearing.
Old 12-19-2008, 01:03 PM
greenchair is on a distinguished road
suggestion....
Did you backup all of the parameters and safely change the memory batteries if applicable?...Safely with the machine powered up is usually a good starting point : )
Old 12-19-2008, 04:03 PM
Mic6's Avatar
Mic6 is on a distinguished road
So what do the greener pastures entail? If you don't mind
Old 12-24-2008, 10:17 AM
plastibob is on a distinguished road
I tried to find this Run In program on the Haas sight and I can't find it? Do you know where it's located?
Old 12-24-2008, 10:35 AM
Merry Christmas, see attachments.
File Type: txt O02020.TXT‎ (723 Bytes, 88 views)
File Type: txt O02021.TXT‎ (695 Bytes, 80 views)
Old 12-24-2008, 10:52 AM
Thank you, and merry Christmas to you.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
