Old 08-13-2008, 03:32 PM
SELECT is on a distinguished road
loading program
hello, im trying to load a work nc file into the haas controler. it will not let me due to not enough space on the controler. is there a way i can drip feed, or run the program right off of the usb?
thanks in advanced,
Old 08-13-2008, 03:57 PM
slatern44 is on a distinguished road
yes, just load the usb stick and when you select the file hit the select program file instead of trying to load it on to your machine and hit start. The only thing you cant do it alter the program or start in the middle. See you manual if you need more details or the haas website.
Old 08-13-2008, 04:51 PM
extanker59's Avatar
extanker59 is on a distinguished road
Do you have a hard drive on the Haas? When I first got on the Haas, I loaded everything in Memory. Not a large space. Then I figured out how to use the hard drive and it opened up MUCH more space.
Old 08-13-2008, 08:39 PM
Thanks alot, i will try that in the morning. Been soo busy dont realy have time to figure out the new machine. just need to keep the spindles turning lol
yes i do have a hard drive. not too sure on how to use it.
Old 08-14-2008, 06:31 AM
extanker59's Avatar
To me, it was a little strange getting a program into the hard drive.
Cursor down to USB Device, Right arrow, cursor to program you want on the USB, Write/Enter, Left arrow, cursor up to Hard Drive, Right arrow, then press F2.
The next fun thing is you can't edit the program in the hard drive but you can start at any tool change (maybe more but I've not tried).
To start at a tool change the screen must not be in Current Comds. When in Memory, press Prgrm Convrs, (the program is full screen) then type the N# for the tool you want to start at, and press arrow down. It'll search and go to it. Press Current Comds, then cycle start.
OK, you already knew that but those were the things that took me a while to get. Good luck.
Okuma MC-6V OSP 3000m Program loading Problem ChrisProphet Okuma 2 09-13-2007 05:21 PM
Okuma MC-6V OSP 3000m Program loading Problem ChrisProphet Machine Problems, Solutions , Wireless DNC, serial port 0 09-04-2007 11:07 AM
help with loading program from card to oi fanuc control dismal Daewoo/Doosan 4 03-21-2007 10:00 PM
Auto loading program in DOS? DennisCNC Computers and Networking 12 05-28-2006 11:14 PM
up loading a cnc program fjd Mazak, Mitsubishi, Mazatrol 14 11-05-2003 05:34 PM
