I've run into a problem in my program that I just can't figure out and I have a feeling that it's something stupid that I'm overlooking. I get a program error of tool is to large when it comes to this line of code, G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 The tool is a .500 end mill, and that value is in the offset menu. What am I doing wrong? on a side note (unrelated) I have been getting an error code of 144 machine will stop functioning in 43 hours... what the hell is this?
__________________ Poor planning on your part doesn't constitute an emergency on my part. |
| To answer your last query first: Haas machines have a time out feature at 800 hours so that if you have not kept up with your lease or finance payments the machine will stop running. I do not know why they cannot turn it off when you pay cash in full for a machine but they do not; all my machines had this alarm. Just contact your dealer or Haas with the machine serial number and they will give you a code that turns off the time out. First query: Tool to big message means you have Tool Compensation active and you have programmed a move that is too small, i.e. less than the tool radius. I am not completely familiar with G13 but it could be your Q value at 0.200. Try changing this to .251 and run Graphics to see if it fixes it.
| Cool that makes me feel much better, I had no idea what that ment. As far as the code goes, from the Haas manual D=tool radius or diameter selection I= radius of first circl(or finish if no K) The I value must be greater than the tool radius, but less than the K value K= radius of the finish pocket (if specified) L= loop count for repeating deeper cuts Q= radius increment, or stepover(must be used with K) F=feedrate Z-depth of cut I and Q must be less than the tool diameter. Their example is G13I0.3K1.5Q.03F10.0 Z-1.2D01 I'm just running this in dryrun mode with the graph and the lines of code on the side to see where the program stops. What really gets me is I have almost the identical line of code (N4581 G13 G91 I.255 K.560 Q.100 F10.0 Z-.106 L5 D01) in another program that I just ran and it works fine.
| When I think about it a bit your problem may not be in the G13 line it may be further down. I have found that sometimes the line that is highlighted when the program stops is not the line with the error; the error is further down the program and the control has found it in look-ahead. Check your code further down and look for things like missing G01 commands after a G12, G13, G02 or G03. These can generate a tool to big message sometimes. When I first started using tool compensation I used to tear my hair because the error messages are so obscure. Eventually I got things straight.
| That's some good advice, so I took a look and I still don't see anything. So here's the rest of the program. G00 Z.1 G01 X1.0 Y-.800 F20.0 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X2.5 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X4.0 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X5.5 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X7.0 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 Y-2.7 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X5.5 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X4.0 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X2.5 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 X1.0 G13 G91 I.255 K.570 Q.200 F20.0 Z-.124 L5 D01 G00 Z.1 T5 M06 D5 (90 deg chamf tool) S2500 M03 G00 G54 G90 X1.0 Y-.800 G43 H5 Z.1 M08 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X2.5 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X4.0 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X5.5 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X7.0 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 Y-2.7 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X5.5 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X4.0 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X2.5 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z.1 X1.0 G13 G91 I.570 F20.0 Z-.065 D5 G00 Z5.0 T6 M06 (.250 drill) S1800 M03 G43 H6 G00 G54 G90 X.566 Y-.800 Z.1 M08 G83 Z-1.150 Q.200 R0.1 F30.0 X1.434 X2.066 X2.934 X3.566 X4.434 X5.066 X5.934 X6.566 X7.434 Y-2.7 X6.566 X5.934 X5.066 X4.434 X3.566 X2.934 X2.066 X1.434 X.566 G80 G00 Z.1 M09 Z5.0 X0.0 Y0.0 M05 M02 M30 % I just can't see it.
No I have .500, the offset screen asks for actual diameter.
| Just asking. I use a Cam system now but when I did code by hand and used G13 on a Matsuura, it wanted just the radius. I haven't used G13 on our Haas yet. So all my offsets are set to zero , then adjusted from there. |
#11
Ditto. ![]() Tomorrow morning I will take the program and run it on my Haas Simulator. It has to be something simple. Incidentally to save typing you could put all the G13 lines in a subroutine and call it after every X move. Also makes editing easier because you only need to edit one line.
#12
![]() So I gave up, sorry.
| New Machine Build- Maybe a stupid question | haroldj | Stepper Motors and Drives | 1 | 04-24-2008 01:17 PM |
| probably a stupid question | mad.sculpture | Linear and Rotary Motion | 4 | 10-09-2007 04:55 PM |
| Another stupid question? | t305100 | General CNC (Mill and Lathe) Control Software (NC) | 15 | 09-03-2006 08:01 PM |
| stupid question | boomer187um | Autodesk Software (Autocad, Inventor etc) | 3 | 08-29-2005 04:16 PM |
| New here, 1st stupid question! | FXRocket | General Metal Working Machines | 4 | 11-03-2004 09:04 PM |
