My Haas VF-OE have a problem. I can't zero return all axis. Alarm 105 (Z servo error too large) appear when home Z axis. Now, spindle is very near table. Pls help! Thank you! |
Check the pressure on the hydraulic conterbalance for the spindle. It should be about 750 psi. If it's much lower than that, the Z servo won't be able to lift the head. Meanwhile, wedge a solid block of wood under the spindle so it doesn't contact the table. |
| Did this happen when you tried to zero return the axies? I think you should check the microswitch that detects the Z home position. If this microswitch sticks the Z axis will go all the way to the end of its travel and alarm when it hits the stop on the end of the ballscrew. The counterbalance pressure will not change this and the spindle itself cannot travel far enough to touch the table.
I have table alarm of Haas. I hope, this can help your. |
the Z axis microswitch fault when travel from USA to Vietnam. Thank you very much! |
| NEED HEELP ALARM #414 Y AXIS SERVO ALARM? | PICMAN | Fanuc | 6 | 04-29-2011 05:20 PM |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| ALARM shuttle drawbar alarm haas | timmydabull | Haas Mills | 27 | 10-30-2009 08:27 PM |
| 434 servo alarm: Z axis detect error | padobranac | Fanuc | 19 | 07-30-2007 03:12 PM |
| Tidal Waves Death Toll Rises to 44,000 | CNCadmin | CNCzone Club House | 5 | 01-03-2005 02:29 PM |
