Many Controllers do not show this.
You could use Sequence Numbers in your Program and Note the range used to get an idea on where you are while it is running.
I have a 2000 Mini Mill. Is there any way on the control to know how many lines of code are left while a program is running?
The Haas editor allows you to number all the lines starting from the beginning, or you can renumber by tool. Either of these will give you an indication of where you are in a program.
