Old 07-31-2008, 07:22 PM
Mic6's Avatar
Mic6 is on a distinguished road
Quadrant marks at 90 degrees
I'm milling a half moon shaped ring about 3.6 outer radius. The finish is perfect except for a quadrant mark at 90 degrees. I circle on at 180 mill around and circle off at 0. ANy ideas what's causing this?
Old 07-31-2008, 07:34 PM
Al_The_Man's Avatar
Backlash!
Old 08-01-2008, 12:14 AM
pit202 is on a distinguished road
or and wrong backlash compensation
Old 08-01-2008, 10:45 AM
Ginger_Ninja54's Avatar
Ginger_Ninja54 is on a distinguished road
most likely the compensation for backlash in parameters.
>>>>>>>>>> Made In England <<<<<<<<<<
Old 08-01-2008, 11:39 AM
Boots is on a distinguished road
All the replies are correct. Your tool is dwelling momentarily while the backlash is being handled by your drives. You can correct this if it is a Fanuc control. I don't know about others but to make sure you are adjusting it correctly you must contact the manufacturer and get the parameter numbers. Another way is to do the Bore with a large Bore Bar or Boring Head. This works well. Just feed into position on the X and Y (for better accuracy on location) then feed in using a Boring Cycle where the Bore Bar stops turning, (at the bottom and positions it's self with spindle lock) then moves off .02 inch before retracting. So as not to drag the point of the tool on your finished surface. Then you won't have to put up with the dwell marks. Do that to rough it out to with in .015 to .020 inch of your finished size. Then Bore it.
Old 08-12-2008, 08:04 AM
durgam605 is on a distinguished road
check your post processor. most will default to break arc at quadrant. if not try a G8 in the arc move and be sure to turn it off afterward with a G9.
Old 08-12-2008, 05:51 PM
Matt@RFR is on a distinguished road
Are you running a Haas?? They don't even list a G8 and G9 is "Exact Stop".
Old 08-14-2008, 12:52 PM
my mistake. im thinkin of a fadal.
2 degrees of a learning Circle Smitty911 Dolphin CADCAM 4 02-12-2008 06:02 PM
how do i get sweep to do more than 360 degrees ??? yamaha_r1 Post Processors for MC 0 09-21-2007 09:41 AM
Controlling stepper motor, readout in degrees KC8QVO Stepper Motors and Drives 5 03-23-2007 03:34 AM
G91 and single quadrant G02/03 Karl_T NCPlot G-Code editor / backplotter 6 11-27-2006 08:49 PM
How to weld plate to tube at 90 degrees? coolman Welding, Brazing, Soldering, Sealing 12 12-23-2004 02:03 PM
