Old 07-20-2008, 04:37 PM
kojack is on a distinguished road
Haas probing Questions
When you Probe a vise corner in VQC probing
ands its finshed and moves the probe to the corner ..
Go into offets and look @ G54 why do the numbers change on x and y
if you press part Zero set .. shouldnt they stay the same ?
Thanks for the help ...
Old 07-20-2008, 06:25 PM
61SedanMan is on a distinguished road
It moves to a safe position near the corner....not to the corner. If it were actually at the corner, your 6mm ruby ball would be touching the vice by 3mm. The reason it changes when you hit part zero set is because you have just designated that safe position as G54 rather than the actual vice corner.
I bet that makes sense, huh? Good luck.
Old 07-21-2008, 01:15 AM
pit202 is on a distinguished road
it moves to the position where you started , just zero your operator positions and run the cycle it should be the same , have checked this in probbing a bore.
5 Axis Haas questions PBMW Haas Mills 12 04-14-2008 11:38 AM
93 Haas VF2 Homing Questions Rcky123 Haas Mills 2 10-23-2007 09:14 AM
Probing and g10 questions matrix control Liontastic Mazak, Mitsubishi, Mazatrol 3 10-04-2007 04:01 PM
Haas Probing binzer Haas Mills 3 09-26-2007 10:52 AM
Haas Lathe Questions - Lots 1ctoolfool Haas Mills 6 08-13-2006 07:47 PM
