Old 07-06-2008, 05:21 PM
CountBraden's Avatar
CountBraden is on a distinguished road
HELP!! Haas Super Mini Mill
Hello Forum,
I was hoping someone could help me in regards to a spindle problem that I am having. The problem occured during the run of my machine's warmup program. While the program was running I opened the door (Setting 51 is set to Off) and the spindle slowed/stopped as always. The problem occurred when I closed the door to resume running the program. I noticed that the spindle did not kick back in to the programmed spindle rate. I also noticed that the spindle will not orientate or lock into position to properly do a tool change. Any help would be appreciated before I have to call Haa$.
CB
Old 07-06-2008, 05:40 PM
Have you done my first problem solving approach? Shut the machine down and then power it up again.
If this does not work I think maybe take the sheetmetal off the head, it is possible the drive belt between the spindle and the encoder has slipped or broken.
Old 07-06-2008, 05:47 PM
Hello Geof...
I have powered down a couple of times with no success. I will look into your other suggestions. Any idea of the cost if I have the Haas people come out. My maintenance warranty has expired
Old 07-06-2008, 06:51 PM
Originally Posted by CountBraden View Post
...... Any idea of the cost if I have the Haas people come out. My maintenance warranty has expired
A few hundred if their hourly rate is the same as my Haas supplier. I had the encoder belt replaced on a VF2 and I think it was about $400 to $500.
Old 07-06-2008, 07:20 PM
Ok.. Thanks .. I appreciate the help
HAAS Super Mini Mill Ford25 Haas Mills 13 09-07-2007 09:01 AM
Super mini mill/coolant tank taylors Haas Mills 8 02-19-2007 08:33 PM
help with super mini mill please daleman Haas Mills 12 08-14-2006 03:32 PM
part for super mini mill daleman Haas Mills 0 05-04-2006 02:03 PM
Engraving on an Arc using Haas Super Mini MIll chop5280 Haas Mills 10 04-10-2006 07:42 PM
