  #13   Ban this user!
Old 07-03-2008, 10:34 AM
PBMW is on a distinguished road
Mastercam will millor anything in about three mouse clicks.
Transform, mirror...
  #14   Ban this user!
Old 07-12-2008, 08:43 AM
speedrider is on a distinguished road
I use Smartcam, and it is quite easy to mirror. I just group everything, then mirror about the zero, then reverse direction of cutter path. Done.
  #15   Ban this user!
Old 07-12-2008, 11:56 AM
Torsten's Avatar
Torsten is on a distinguished road
The simplest thing to do is to run mirror image on the machine and get left handed cutters. This way you will not loose and edits made on the machine by reposting and you will be able to use the production Programs.
You could charge the customer for the purchase of the cutters.
  #16   Ban this user!
Old 07-12-2008, 05:37 PM
big_mak is on a distinguished road
Torsten,
Problem with that is mr. operator for gets to change cutters when the turn everything off and Smash. If I tried to charge my customers for an extra set of cutters, they'd be running elsewhere to get their work done!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
  #17   Ban this user!
Old 07-22-2008, 02:21 AM
dinoracer is on a distinguished road
In the Haas control go to settings pgm, type in 45 then down arrow. Right cursor will have that line blinking. Write/enter will turn it on and will have Xmirror shown on the monitor. That will mirror X. All you have to do is put the x zero on the opposite side. If I have to have a left and a right hand part. I will put hard stops on the table or use a dowel pin. Then use g54 for left hand of the material, g56 for the right hand of the material. That way I know where everything is. X mirror will work for cutting alum, but for anything else the surface finish will need help.
Sean
  #18   Ban this user!
Old 07-22-2008, 10:09 AM
warrenb is on a distinguished road
I've never heard of mirroring a part reversing the spindle direction so you wouldn't need left hand cutters.
  #19   Ban this user!
Old 03-30-2010, 06:54 AM
Adilson Kim is on a distinguished road
Someone have a Permanent Licence Key for SmartCAM Freeform Machining V10 or V11.5?
I have only a Tenmporary Licence Key. tks
  #20   Ban this user!
Old 04-08-2010, 12:06 AM
TonyAllen is on a distinguished road
Originally Posted by flashno View Post
I agree with the others, using mirror or sign reversal at the machine will give mixed results - I wouldn't, on what's evidently a complex part.
But Mastercam CAN do this - just not with 1 or 2 mouse clicks. Exact method will vary depending on your version (8, 9, X, X2?), but it's basically, select all entities, Xform, Mirror, X axis. Regen all your toolpaths.
Then use backplot / verify to see what you have. Hole paths usually come out OK, as do *MOST* pockets. Contours generally retain original offset side, but since the MIRROR command changes the direction of the chain, you may need to reverse each one to have the tool on the correct side of the contour, and retain climb cut direction. Surfaces like flowlines can also change cut or step direction. It takes a little time to go through, but it beats the heck out of starting over!
As to the question of, should it be easier for $15K? I'll leave that one alone... but it WILL do what you want.
Ed
Hi 61Sedanman
with Mastercam x, x2, x3, x4 this works great and is easier than it sounds follow his instructions and U will be happy ..MC will regen the tool paths..almost everything I program is left and right hand
Tony
RFQ Can anyone make this part? Milt Employment Opportunity 6 09-18-2007 07:34 AM
Best way to make this part skmetal7 General Metalwork Discussion 24 09-04-2007 09:19 PM
Can anyone make this part? Milt General Metalwork Discussion 1 09-01-2007 07:48 PM
Would any DIYers (in the US) be willing to make a part for me? 11bravo CNCzone Club House 14 04-02-2007 03:04 PM
How do you make all toolbars open at the last spot you left them? DigitalDeath GibbsCAM 1 02-02-2005 12:24 AM
