Old 06-28-2008, 06:35 AM
northstarr is on a distinguished road
Question Problem: Feed back on Screen from Spindle
We have had to replace the screens on our mid nineties vintage, HAAS VF-2 and VF-3. We did notice on the new screens an "extra" plug.
Nice having a screen you can see, HOWEVER, now when the spindle rotates
you get squiggles and such across the screen(s). (kind of like a TV screen with static if it's in the same room as a microwave when it's running)
These are the monochrome screens.
How can we(I) isolate the screen from the feedback? To eliminate this
problem.
Any insights would be appreciated.
Old 06-28-2008, 08:38 AM
serviceman's Avatar
serviceman is on a distinguished road
you need to take the 9 pin connector that goes to the screen coming from the control panel not the cable from the monitor and cut it open or unscrew the case and you need to solder or splice the shield wire to the ground wire i think pin 1 or 5 ohm it out and find the ground.
REYTECH Machine Service Corp. CNC repair NY, NJ
http://www.reytechmachine.com
Old 06-28-2008, 10:02 AM
We had a similar problem on a lathe and it was not really feedback, it was the video card vibrating slightly when the machine was running and working loose. We wedged it with some little foam pads and the problem disappeared.
new to sit. I would like some feed back on these machines cmmi General Metal Working Machines 0 03-07-2008 10:06 AM
Anyone dealt with dyna cnc? any feed back? turboboy DynaCNC 30 01-21-2008 01:26 PM
Hurco 5M Need feed Back Please roadbyte HURCO 0 03-25-2007 06:10 PM
Give feed back CNCadmin Machinist Feedback 0 09-22-2005 11:42 AM
