Old 06-26-2008, 07:44 PM
PaintItBlue is on a distinguished road
vf2 setting for 8x program names?
hello, i was wondering if there is a setting on a vf2 ss non usb/ethernet that will let me save program names to 8 numbers instead of 5. I read about some machine having this setting but it was a while ago and can;t remember if it was for hass. Not at work so i can;t check ,...
thanks
Old 06-26-2008, 08:46 PM
The program name; that is the Onnnnn, at the top of a program is one letter and five numbers.
The file name under which so save a program onto a usb drive or floppy uses the normal 8.3 format; i.e. ABCDEFGH.txt
Or you can use the Program name Onnnnn.txt
Or for that manner any name that works for Windows; only the first eight characters will show up in the directory list on the Haas when you open the usb or floppy.
Old 06-26-2008, 09:40 PM
Thanks for the quick reply, yah that bit me today, haven;t seen o2222~.txt in a while, like since windows 95 or 98. I made the mistake of copying my laptop "O2222 v1.5 1 1/8 - 20.txt" to the cnc and it truncated the file.
But what i was refering to was a post somewhere i saw that some machines have a setting on/off that lets you specify Onnnnnnnn instead on Onnnnn. I may of miss read it, it was almost a year ago,.
Old 06-27-2008, 01:45 AM
Are you sure it was referring to the program name? I while back Haas did change things so the line numbering could go above 5 digits; now I think it is possible to number up to 8 digits, 10 million lines. But I have never seen anything about the program name being different.
Names ErnieD Trade Shows and Events 0 03-20-2007 05:48 PM
Setting or Program fault? Kiwi BobCad-Cam 20 04-28-2006 07:42 AM
List of program names and #'s daking Fadal 3 01-16-2006 10:39 PM
Plus sign next to names? DAB_Design Forum Questions or Problems 0 06-08-2005 11:26 AM
NAMES Expo johnbutler Trade Shows and Events 0 04-13-2004 09:57 PM
