Old 06-19-2008, 05:56 PM
stovepipesteve is on a distinguished road
cant rigid tap in canned cycle,why?
im running a VF3 Haas and loving it.Probes and all.
for some reason when i go to rigid tap in a canned cycle , it will tap my first hole ,then rapid to the other holes but not tap. I always have to go back to a tap head with a G84 instead of G184.
T3M6(1/4-20 rigid tap)
G90 G0 G54 X5. Y.5 M8
G43 H3 Z1.0 S300 T2
G98 G184 R.1 Z-.7 F15.
G91 X.5
X.5
X.5
X.5
Y1.
X-.5
X-.5
G80 G0 Z6.
T4M6......
Old 06-19-2008, 08:15 PM
Vern Smith is on a distinguished road
I'm probably not understanding something but why G184? I use G84 and rigid tapping does multiple holes without any problems, if peck tapping is needed it will accommodate that as well assuming you have all the necessary parameters turned on.
Vern
Are you tapping a non-vertical hole? G184 is for non vertical holes.
It is possible that G184 will not let you do a sequence of X and Y moves because it is a non-modal command.
Switch to G84, it can be used for Rigid Tapping so long as you have the Parameters and Settings turned on.
Newbie- G84 CANNED TAPPING CYCLE mmussack Mastercam 15 11-25-2008 11:02 AM
G76 Canned cycle Stebedeff Fanuc 1 02-07-2008 12:42 PM
Canned drilling cycle on 0TB guhl Fanuc 0 11-22-2007 07:33 AM
canned cycle on Haas GITRDUN G-Code Programing 6 11-22-2006 12:44 PM
canned drill cycle nitrosnfr General Metalwork Discussion 2 05-24-2006 11:50 AM
