  #13   Ban this user!
Old 06-23-2008, 03:45 PM
Shop junkie's Avatar
Shop junkie is on a distinguished road
I do a few other things too, like:
G53 Y0 Z0
M1
after every tool to make it easier to set up.
etc...
I've never seen that before, what does that do to make it easier?
I would have done the M0 to apply tapping oil but with the TM1 it's all open so I just do it before the tool change. A little moly-d and let it go.
Poor planning on your part doesn't constitute an emergency on my part.
  #14   Ban this user!
Old 06-23-2008, 04:18 PM
extanker59's Avatar
extanker59 is on a distinguished road
On the Haas, you don't need to send it home before a tool change but on the Matsuura (that I started on), you did. So my consistancy is to always put a home move in after every tool. I like G53 (Machine reference) because you can call out exact locations in other axis- to bring the Y axis close to the operator for example. I also will call an X position to better position the part for the operator (instead of off to one side or the other if that was the last location).
Like if you have a 40" travel table, you can bring the table to the center in X and closest to the operator with:
G80 M9 (after drilling for example)
G53 X-20. Y0 Z0
M1
It will move in Y axis right away so just make sure the starting point is high enough to clear any obstructions. Or use:
G80 Z3. M9 (or higher)
G53 X-20. Y0 Z0
M1
The M1 is just optional stop. During set up I almost always have the optional stop button on so I can check each tool's work before the next tool.
I like to call up the tool before applying tapping fluid so I can put it on the tool too. Overkill?
Rigid Tapping NinerSevenTango Mach Mill 20 11-06-2010 02:59 PM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Rigid tapping metric threads msomerville Milltronics 14 07-10-2007 09:47 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
Rigid Metric tapping... Need a bit of help saabwagon Haas Mills 14 04-06-2006 06:17 PM
