Old 06-19-2008, 11:16 AM
Chris Swier is on a distinguished road
Haas TM2 Leaking Coolant
My TM2 is leaking coolant out the back of the machine, and I know this problem has been brought up in other posts as a common issue.
What ideas have people tried that successfully held back the tide?
Old 06-20-2008, 10:57 PM
automizer's Avatar
automizer is on a distinguished road
im not to sure about this problem but I know the Mini Mills have a lot of issues. A good indoor out door sealant and for the larger holes put in chunks or closed cell foam.
Good luck with fixing the holes coolant leaks are never fun
I'm not lazy..., I'm efficient!
HAAS GR-408
Tags
coolant, haas, tm-2, tm2
HAAS VF-6 Thru Spindle Coolant kwhizz Haas Mills 1 04-11-2008 09:46 PM
Problem- thru spindle coolant leaking GARY DAVIS Fadal 4 03-25-2008 08:28 AM
Coolant leaking slowly on back of VF3 Rocko1 Haas Mills 3 12-06-2007 06:38 PM
Haas facemilling:coolant yes or no joesimmers Haas Mills 16 06-15-2007 09:23 PM
Haas TL-2 Coolant ? 100 Haas Mills 2 04-14-2006 06:11 PM
