Old 06-13-2008, 03:34 PM
l u k e's Avatar
l u k e is on a distinguished road
VF2 and Shop floor
I'm going to purchase a VF2 in the next few months for a home shop. I read a few weeks ago that your concrete floor thickness can be a concern. So it has me a little bugged out about my situation.
I poured the concrete myself several years ago so I know the specs first hand. My slab is exactly 3 1/2" thick with fiber mixed into it as it came off the cement truck. Suposedly if you use fiber you can get away without using wire in your pour.
Can I expect to have any trouble with the VF2 on this slab?
Old 06-13-2008, 03:56 PM
What kind of base did you put under the concrete, nicely compacted road base material? If the underneath is not providing a good suppport I think you might be marginal, but the fiber will certainly help.
I have two smaller machines, about 5000lbs each on a 2" - 3" slab that has nothing but topsoil under it and what I did was use pads of steel plate to spread the load over a larger area than the little pucks the levelling screws sit on. Between the plate and the concrete I put a 1/2" thick piece of dense polyurethane foam; my theory for this was that it compresses and spreads the load evenly over the concrete surface, not concentrating at just the high spots where the steel touches. So far a few years on I have not seen any extra cracks in the floor.
Old 06-13-2008, 04:06 PM
l u k e's Avatar
I actually had to build the floor up around 18-24 inches (under the concrete) because the shop was in a low spot. It was built up a few inches at time with "AB" (a term used out west to grade the material). It's what is commonly used to "bed" concrete in this area, it compacts very well. Every few inches I compacted the AB with a gas powered compactor.
I'm pretty confidant that the bedding was done very well if not over done.
Old 06-13-2008, 05:49 PM
Originally Posted by l u k e View Post
..... Every few inches I compacted the AB with a gas powered compactor.
Lotsa fun using those compactors, after a few hours your teeth are all shooken loose.
EDIT: Pushed the button too soon, hadn't finished.
You should be fine. Being a 'belts and braces' guy I would probably use my steel plate idea but at my business I have a reputation for BLABSHE.
Old 06-13-2008, 10:45 PM
automizer's Avatar
automizer is on a distinguished road
You should be fine, I looked in to this when I was putting down my floor for my machine and I way over built it because there was a lot more going on it as well. Mine is 6" thick with rebar on 10" centers. You may have a problem in you start loading more on the floor around the machine. Like is this where you park your car? Geofs idea above would remove all worry. But when your machine shows up ask your riggers about some horror stories my riggers had some good ones.
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 06-14-2008, 10:19 AM
l u k e's Avatar
I'll likly go with the steel plate , thanks.
BLABSHE?? lol
Old 06-14-2008, 12:03 PM
BLABSHE?? lol
Built Like A Brick S**t House Engineering
Old 06-14-2008, 04:00 PM
l u k e's Avatar
LOL, good one.
Looking For Shop Floor Mats there&back Safety Zone 6 03-02-2009 10:39 PM
Shop Floor Paint HiTech CNCzone Club House 2 02-16-2006 12:55 AM
New shop-Floor?? bdrmachine General Metalwork Discussion 5 09-19-2005 02:41 PM
Shop Floor CNCadmin General CAM Discussion 2 01-13-2004 04:32 PM
Shop Floor CNCadmin General CAM Discussion 5 06-23-2003 09:19 AM
