could anyone please tell me do i need to buy a phase rotation tester before i wire in my tm2 or can i just wire in and if spindle goes backwards swop two wires of the three phases or will i damage the machine. |
| Don't worry, not on the TM machines anyway. Your spindle will not go backwards, it is driven by a vector drive that synthesizes variable frequency three phase AC from the DC buss. The incoming three phase supply is rectified onto the DC buss and the phase relationship coming in is not important for this. The reason the board has the phase detect is that the same board is used on all the Haas machines and when it is a lathe with a hydraulic pump that runs on the incoming three phase supply the phasing has to be correct for this pump. Also on the VF machines with high pressure through spindle coolant I think the pump motor is a three phase and must rotate correctly. The other coolant pump motors do run from the incoming supply but they are single phase so again the phasing is not important.
| determining phase sequence | Stepper Monkey | Phase Converters and VFD | 3 | 06-07-2008 07:55 AM |
| Need Help!- what size 3 phase coverter haas vf-2 | mls | Haas Mills | 1 | 04-05-2008 09:01 PM |
| cut sequence | camtd | Surfcam | 2 | 06-13-2006 12:26 PM |
| Sequence #'s | Mountainwildman | Post Processors for MC | 2 | 04-02-2006 12:25 PM |
| Wire sequence? | scratch_6057 | Stepper Motors and Drives | 3 | 03-30-2006 08:33 AM |
