If you mean reverse the + - signs in the program that is easy.
Edit
F1
Modify
Reverse X Y
Then just designate which one you want to reverse.
Gary
How do I reverse the "X" axis guys. I want the plus to be minus and the minus to be plus.
thanks all
Edit
F1
Modify
Reverse X Y
Gary
come on........ I can be the smartest ass you know, I work in a machine shop.
I mean on the machine itself.
Setting #45 "Mirror Image X Axis" will do what you want..
If you want it to be a permanent change you would have to dig into the parameters..
jybute,
Why do you want to do this?
Sorry, I didn't know you worked in a machine shop.come on........ I can be the smartest ass you know, I work in a machine shop.
Maybe this will help a little more....
No
Gary
I work for a shop that is part of a larger group of companies. two of the three have VF6 VMC's. But the other has just purchased a horizontal. We would like to be able to run the programs for the parts that the three big shops produce, (we use gibbscam) without having to change the .vnc file.
I know there are other ways of going about this, but I thought I would give this a try.
