Old 05-26-2008, 01:23 PM
jstucken is on a distinguished road
Software vs floppy drive
On my vf2 i do not have a floppy drive. I am having problems hooking up to transfer programs via rs232 port. I had a demo version of cimco and its not working. I want to know would it be easier/ cheaper to take a floppy drive from a PC and hook it up to the haas. I know a floppy drive from haas is like 400 bucks. Or is there any software out there that is free/ cheap that will work. I don't want to spend any more money. thanks
Old 05-26-2008, 08:47 PM
gar gar is offline
gar is on a distinguished road
080526-1939 EST
jstucken:
You really haven't said anything about what you tried with RS232 --- settings at both ends, cable pinouts and how connected, cable length, computer, operating system, what doesn't work, exact results, and anything else.
Cimco software works very well and so does HAAS RS232 if there are no damaged components.
Go search for some of the various discussions I have had on troubleshooting RS232.
I think that the floppy drive on HAAS is less reliable than RS232. Also floppy disk quality seems to have degenerated recently.
Old 05-27-2008, 12:09 AM
*Registered*
Mike Stevenson is on a distinguished road
RS232 is the only way to go. The floppy drives get dirty all the time.
Old 05-27-2008, 12:19 AM
WayneHill's Avatar
WayneHill is on a distinguished road
hi jstucken,
Welcome to the CNCZone. The HAAS serial wiring has been hashed, re-hashed, and who-hashed here many many times. Use the search feature of the forum.
Wayne
Wayne Hill
www.codemangler.com
Old 05-27-2008, 09:52 AM
extanker59's Avatar
extanker59 is on a distinguished road
I use a memory stick. Easier and quicker than floppy discs, cheaper quicker set up than rs232. Do you have that USB port?
Old 05-27-2008, 10:51 PM
usb
No my CNC does not have a USB port.
Old 05-27-2008, 10:57 PM
*Registered*
So you should use the RS-232 for best speed, quality and reliability . Break down and buy or make a good cable and get some working communication software. Any other solution is chaos.
Old 05-28-2008, 09:34 AM
JDenyer232 is on a distinguished road
Try DNC4U, that's what we use and it was pretty easy to set up, they let you try it for 60 days, and then you have to buy the license, was $139 to purchase a license for one computer, you can run up to 64 machines per computer/license. This software will transfer files to and from the machine as well as drip-feed. They have a nice file que utility with a repeat count for machining multiple pieces. I have no affiliation with the software company, just a very happy user. Hope this helps.
Need Help!- DNC from floppy drive jwknow Haas Mills 5 03-11-2010 09:39 AM
Has anyone tried a Floppy drive adapter ? meadowtech Controller & Computer Solutions 1 04-18-2008 05:51 AM
Foolin around with an old floppy drive compuslave Stepper Motors and Drives 9 12-15-2007 11:17 AM
Yasnac floppy drive dewcnc Machine Problems, Solutions , Wireless DNC, serial port 0 03-19-2007 01:19 PM
Converting from Floppy Drive to USB TZ250 General Metal Working Machines 3 09-06-2006 01:55 PM
