Old 05-21-2008, 07:51 PM
Cory is on a distinguished road
Replacement OMP-40 Probe Body
Does anyone have a rough guess how much the cost of a replacement probe body is?
Someone crashed ours today pretty bad. totally wrecked the body on the top of a vise. Shockingly enough, the stylus remains intact and good as new. Go figure.
Old 05-22-2008, 05:35 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Cost
I can tell you exactly what it costs.
$950.00 FLAT RATE CHARGE plus shipping for Renishaw 1-847-286-9953
A new probe costs $3,800.00 Ouch!!!!!
My Local HAAS Field office offered no replacement plan other than purchasing a new one.
You have to send your crashed unit in and they will either repair your unit or send you a rebuilt replacement.
Just some words of caution from another dummie that made that same mistake.
The programming supplied by HAAS has (CERTAIN) protected moves. i.e. if you place the probe above the recommeded .4 above the part it will alarm out and the probe will stop. If you are doing a x + surface probe and the probe is too far away from the material it will alarm out and stop. If the probe (fake ruby tip) touches something before programmed object it will alarm out and stop.
Here is a scenario that will get you in DEEP trouble FAST.
All was well with me until Sunday evening. I crashed my Renishaw probe into the vise. A slight $950.00 setback. I was doing a Y web on a .4 diameter piece. I did the probe the first time at -.375. I wanted to go a little deeper on the diameter of the part that was extended from the vise. The issue was that I put in 4. instead of .4 and got in a hurry and didn’t take a second look at the entries prior to running the probe. I saw the probe go by the part and had my hand on the feed hold button but thought for just a second and reached for the Emergency Stop button instead. WRONG CALL. The probe beat me to the vise by about 1 millisecond. If I would have just pressed the feed hold like a good boy I would have been O.K. Guess that 62 year old brain didn’t cut the mustard. Ha Ha
The probe will alarm out in certain instances. i.e. if the probe is too far away from the part on a Z or X or Y Probe. Needs to be about .4 away to get it to work. However if you make a dumb move like me and give it a large negative number (longer than the ceramic probe tip) on a X or Y web and the body of the probe hits something before the ruby tip does you are in for a treat. If the ruby tip would have hit something first I would have been O.K. Just got a little to complacent and got bit really hard. I think HAAS should have programmed a protective move (or a least a warning that you have exceeded the probe tip length) to prevent a movement longer than the probe tip when doing Z Probes. I realize that Renishaw offers different probe tips and some (may) be longer.
I intend to talk to someone at HAAS factory as I think when an operator tries to make a move that may be hard on the owners pocketbook that a warning should come up on the screen and al least let you decide if you have just entered a number that could result in a crash. I am a newbie and it bit me hard in the pocketbook.
I just got my rebuilt probe back from Renishaw yesterday and have installed the rebuilt probe on the tool holder. There are six set screws you have to remove to send it to Renishaw. It is a real treat to get it zeroed in.
I still need to run the calibration program to set the tool length for the probe. Easy task. Then I need to mount my ring gauge on the table and run the calibration program for the X Y axis.
Then hopefully it will work fine and I will have learned an expensive lesson. Hope this little message may prevent someone else from making the same mistake.
John
Old 05-22-2008, 12:45 PM
John
Yeah, I know exactly what went bad. Normally I'm the only one running the machine, but we had someone new who has taken a CNC class and decided to run their code without checking with me first/setting rapid overrides.
He had just finished setting his WCS with the probe, hit cycle start, and the probe immediately rapided into the top of the vise. Somehow, like you, it managed to avoid even touching the stylus, and just rammed the crap out of the probe body. He had a G90 G28 Z0. in his insurance line instead of a G91.
There were about 10 different ways we could have avoided that mistake... proofing the program at 5% rapid, reading the code first, waiting for me to come over and look at the code, switching to a tool that costs less than $1,000 so it would have crashed instead.
I thought it wasn't too bad when I had to adjust the runout in my probe body. I tweaked it a little bit when I accidentally hit the auto z feed button somehow, and broke the stylus. Only took about 5 minutes to get about 0.015 down to nothing that I could measure on my 0.0005 indicator
What is the $3800 charge for, if the probe is $950?
Old 05-22-2008, 01:30 PM
Probe Cost
A brand new probe is approximately $3800.
A rebuilt exchange probe is $950. You need to send your old one in for exchange to get this price.
John
Old 05-24-2008, 09:12 PM
Vern Smith is on a distinguished road
The Renishaw folks must have found themselves in a rather interesting position when they sold the $5,000.00 package to Haas. Who would pay $3,800.00 for the spindle probe when they could call the local Haas HFO and get the entire kit (spindle probe, tool setter, and transponder unit) for $5,000.00?
Short answer, the $950.00 probe exchange program. I wonder if there is a $950.00 exchange program for the tool setter as well? Considering it's positioning requirements and 3+ inches of height, it's not a hard job to T-bone it with a tool in a heart beat.
Vern
Old 05-24-2008, 09:33 PM
Pricing
Hi Vern,
I thought that the $5,000 price option only applied to new machine sales or agreements made at the time of purchase such as yours. ?????????
Old 05-25-2008, 08:52 AM
John,
The Haas/Renishaw probe accessory has a Haas part number like all their other replacement parts. I think anyone can call their local HFO, order the accessory by part number and get it for five grand.
I could be wrong, it's a hell of a lot of neat technology for the price. Hopefully, someone on the forum, out of our area, will make the call and find out.
Old 05-25-2008, 08:59 AM
Vern,
You are right on. It is the best and most used option I ordered on my TM-1P.
I love it.
John
Old 05-25-2008, 02:07 PM
Vern,
I love it.
John
I agree. In a given day we could run 4-5 different parts, with just a few of each. Without dedicated fixtures or anything like that, the probe makes everything incredibly easy compared to having to edge find/indicate.
Old 05-25-2008, 04:49 PM
I dug out my invoice, the part number is VQCPS for anyone interested in inquiring about price and availability.
Like John and Cory 90% of my projects are 5 or less relatively small pieces. Before the probe-tool setter my set up time to run time was 3 to 1, with the probe it's closer to 1 to 1. The tool setter saves more time then the probe for me because most of my programs use 7 to 10 tools.
The probe makes very accurate and fast set ups, especially if you're using a boss or hole. I think guys with a lot of experience using the new touch off stuff can probably go about as fast as the probe for finding a corner (with a lot smaller investment).
Vern
  #11   Ban this user!
Old 05-25-2008, 06:11 PM
Vern
I don't save as much time with the toolsetter as the probe. I have about 16 tools that never leave the toolchanger, and I fill in the last 3 when I have an oddball drill/tap/EM.
The place where I find myself saving a ton of time is like you said, with bosses and bores. I'm constantly finding that I'm setting my WCS to the center of a boss/bore, and it takes FAR less time to probe it than to even setup my indicator.
  #12   Ban this user!
Old 05-25-2008, 08:29 PM
16 tools !!! you lucky devil, I thought 10 would be more than enough but soon learned differently. Most of my stuff has 2, and some times 3 different sized threaded holes. That eats up tool slots real fast.
I have several fixture plates that are so long (30 plus inches) that they have to span 2 vises. Rather then screw around bumping and shimming to get the plate in straight I clamp it in and use the probe to determine how far it's skewed in Y end to end. Then do the trig and plug the out of parallel degrees into the G68 rotation box and away you go.
I realize there are some snow covered purists on this forum that would never have two vises out of parallel but us lesser accomplished amateurs need to take advantage of any crutches that come our way.
Vern
Need Help!- Cut body, teeth weirdharold Mastercam 5 03-28-2008 08:18 AM
Super Probe 17 Functions in one probe thegimpster PIC Programing / Design 0 01-25-2008 12:46 PM
Any body mapping their screws Ron111 Benchtop Machines 2 06-20-2007 10:05 PM
RFQ- Paintball gun body Rudisill Employment Opportunity 15 06-08-2007 09:10 AM
RFQ for Aluminum Jig Body rvoigt Employment Opportunity 2 04-10-2006 07:14 AM
