Old 05-16-2008, 11:07 AM
flashno is on a distinguished road
Trunion table - brake engagement
Hi all,
We have a TR-110 (really small trunion!), and have been successful in working through learning 5-axis positioning setup & programming. We're moving on to 5-axis simultaneous stuff, and are seeing this problem:
The A and/or B axis brakes engage and disengage when cutting a swarfed wall, producing pauses in the cut, not a smooth motion. Our CAM (MasterCAM X2) is not outputting the brake codes (M10 thru M13), rather, the machine (VF-5) is doing this itself whenever the A or B aren't moving for a second or 2.
Any parameters to look at here, maybe to lockout or delay brake engagement when doing 5-axis simultaneous?
Thanks,
Ed
Old 05-19-2008, 07:08 PM
omy005 is on a distinguished road
You need to set up your post to output the brake command M codes before and after simultaneous 5 axis movement. For indexing or positional moves just let the control do it for you. This it what we have done and it worked well.
Andrew.
Old 05-19-2008, 07:51 PM
*Registered*
Mike Stevenson is on a distinguished road
Turn your brakes off. You do not use them when cutting 5 axis simultaneous.
Old 05-20-2008, 10:46 AM
Thanks, Andrew & Mike, as usual, I was looking too deep - a simple brake off code before the toolpath did the trick.
Ed
Old 05-24-2008, 06:32 AM
timf is on a distinguished road
i'm waiting on the full 5th software right now and will be writing my post soon.
this was good info
thanks guys
New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) RotarySMP Bending, Forging,Extrusion... 20 09-06-2010 10:56 AM
Dynamic brake millman52 General Electronics Discussion 5 11-05-2007 10:51 PM
Brake rebuild hmc710 Bridgeport and Hardinge Mills 3 07-02-2007 10:33 PM
bdp interact1 brake PRIOR666 Bridgeport and Hardinge Mills 1 05-29-2007 02:14 PM
