Old 05-14-2008, 04:36 AM
mls mls is offline
mls is on a distinguished road
Z load on vf-3
I just got a 2006 vf-3 when it is not moving it is at 50 to 60 percent load on z axis when it is moving it goes down is this normal
thanks Mike
Old 05-14-2008, 07:35 AM
extanker59's Avatar
extanker59 is on a distinguished road
I'm not a tech but it has to be the servos holding the weight of the spindle up. When it moves down it's working with gravity and just slowing it down so you get lower load. BTW we have a VF-2 and it's the same.
Old 05-14-2008, 09:45 AM
thanks Mike
Yes it is the weight of the head being carried by the servo.
Do you know if the machine has the Power Failure Detection Module Installed?
Without this module on some machines when the power goes of the spindle will drop anything up to 0.1". This happens because the magnetic brake on the servo clamps down to slowly when the servo loses power.
Watch the position display when you hit Estop and see if the spindle drops. Have someone watch the spindle when the power is shut off at the back of the machine and when the power is turned off at the panel breaker.
If the spindle drops with any of these you need the module, otherwise if you have a power outage during a long job you have probably lost a tool and the part.
Old 05-14-2008, 09:50 AM
extanker59's Avatar
Thanks Geof, now I know what to ask for next time we get a Haas. We've lost power once and it did scrap the part and the tool. I didn't know they had a solution. The Matsuuras I ran in a previous job didn't do this (great machine).
Old 05-14-2008, 09:57 AM
The module can be retrofitted at a cost of about $500 -$600. I had it done on one machine.
Old 05-15-2008, 10:54 PM
mls mls is offline
thank you for that info I have been busy and did not thank you sooner
thanks mike
Wont load Mr Bits LinuxCNC (formerly EMC2) 1 04-22-2008 06:19 PM
Haw to load picture kal_pesh Mastercam 1 04-02-2008 08:06 AM
10 T load from memory Bitshird Fanuc 0 03-19-2008 11:00 AM
Help With Dc Load Meter Led dannystooblue General Electronics Discussion 6 05-20-2007 09:58 PM
Fanuc 0M PMC load ETNOM Fanuc 4 05-27-2006 02:21 PM
