| Hello all! I am new, so please excuse my ignorance on the subject. I am looking to buy a used VF-2SS machine (2006) and ship it to my parter in Europe, but it does not have some options we were looking for: - Intuitive programming system for Mills; - Early power failure detection module; - High-Speed Machining with Look-Ahead; - Internal High-Voltage non-Isolated Transformer, 400V, 50Hz, 40/30 hp (adaptable for European power) or can it be any other compartible external transformer? Please share your experiences. Thank you all... |
| Intuitive programming can be retrofitted, it is just software. Power failure detection can be retrofitted; it is a little module that has to be wired in. I think High Speed machining is more complicated because it needs extra components on the board; probably will require a whole new board. You could probably use an external transformer. BUT...you may run into serious problems with CE. I do not think machines sold in the US meet the full CE requirements. Do a lot of checking on this, you might find the machine cannot be imported into Europe.
Pretty sure that if it isn't, you can get it retrofitted to any newer machine. |
I had High Speed Machining added to my GR510 and the spec sheet that came with the machine mentioned something something about an added math coprocessor. I have never checked regarding the 200 hour trial.
I could be making that up. I just thought I saw it listed somewhere under the features available for trial. |
| VMC and HMC try-out options: High-Speed Machining(Parameter 315, HIGH SPEED) Rotation and Scaling(Parameter 57, ENA ROT & SC) Spindle Orientation(Parameter 57, M19 SPND ORT) Rigid Tapping(Parameter 57, RIGID TAP) Macros(Parameter 57, ENABLE MACRO Lathe try-out options: Spindle Orientation(Parameter 57, M19 SPND ORT) Rigid Tapping(Parameter 57, RIGID TAP) Macros(Parameter 57, ENABLE MACRO) However, I'm curious about high speed machining. Since the CPU is upgrade every few years is the the speed of the current generation controller equals to the previous generation controller with HSM? |
#10
| I bought HSM after my 200 hour tryout ran out on my '07 Mini Mill. Haas sends you a code that you enter into the controller. No extra processor required. If you're trying to manage the 200 hour tryout, be aware that the counter runs whenever the machine is powered on, not just when a program is running. My HFO thought the 200 hours was based on programtime, but it ran out because I left the machine on for several days in a row. Turn it off when you don't need it. |
#12
| Does anyone really see a benefit to the HSM option? I suppose it may be beneficial for parts programmed at the console, but for CAM programmed parts, we run a HSM plugin in GibbsCAM and it rounds the corners, and slows down for corners where appropriate in teh code. I ran one cycle with the HSM turned on and one without and didn;t notice any difference. John |
| Adding features | bdrmachine | Solidworks | 3 | 01-14-2008 07:39 AM |
| Adding a fan to the X3 | Antonyong | Benchtop Machines | 2 | 04-25-2007 11:19 PM |
| adding 3rd motor | arelewis | CNC Plasma and Waterjet Machines | 4 | 12-21-2006 09:26 PM |
| adding 4th&5th axis | cnc prog | Daewoo/Doosan | 1 | 09-25-2006 04:26 AM |
| Adding a 4th | Shizzlemah | Fadal | 5 | 12-01-2005 05:16 PM |
