Has anyone used this oil separator (or any of the Zebra models) to separate tramp oil in their HAAS machine? I need to find something that effectively maintains proper coolant balance because I don't run my machines on a daily basis. If I let them sit wothout pumping the coolant through the system for more than a few days, I get foaming problems. I use Blaser coolant, and have for the past 10 years and apart from foaming issues I find this coolant to be very good. I machine 50% 6061-T6 and 50% plastic (Acrylic & Peek) I appreciate your help on the subject. |
We have the same problem. what we have come up with is to buy some anti-foam agent from a pool supply co. Or you can also use "Rug Dr." or equivalent. I know, not much help here.
__________________ Just a good ol' boy, never meanin' no harm. Joe |
| Thanks JoBwan for the suggestion regarding foaming. I have anti foaming agent but if the coolant becomes contaminated with too much tramp oil it really doesn't help. I'm getting a Skimerator on loan to try it out and if it works effectively I'll buy it. |
I'm using the Zebra Sidewinder and have been for about 4 years. In addition, I'm using a fish tank air pump on all our coolant tanks. This allows us to agitate and aerate the coolant. http://www.terrificpets.com/pet_supp...pumps/4469.asp http://www.zebraskimmers.com/oil_ski...tml#Sidewinder |
Are you using a bunch of aerators in your tanks to keep the coolant from stagnating? |
| I'm not familiar with the Skimerator, but if it's from Zebra I'm sure it's good stuff. I have not used the belt type skimmer only because of the limited room on the HAAS MiniMills. As for the air pumps, we use only one per tank. |
| I used this one. It worked pretty good. Ran it twenty four seven. The pumps eventually go out but it works best at night after you leave as the coolant settles and the oil rises to but skimmed by the ingenious little float system it has to skim the surface. As you can see in the diagram the pump sucks the coolant behind the float causing it to drop enough to let the oil on the surface flow over the top. http://www.design-mfg.net/Skimerator/Skimerator.htm |
#11
| Where using something at the shop I'm at now that is more portable than the Skimerator. Oil Skimmer - Floating Oil Skimmer And Industrial Oil Skimmer The picture in the link looks like what we have except for the tank in front of the unit. If the unit behind it is the same as ours it has wheels on it so it can be moved from machine to machine. Also if it is the same that unit in front with the floats in it would represent you machine system tank. The intake has floats so it skims and recirculates the oily coolant off of the surface. |
| New SL-30 model | WOLOG | Haas Lathes | 45 | 05-07-2008 10:05 PM |
| RPM beyond 3200? | Rich05 | Industrial Hobbies (Support forum) | 1 | 03-31-2008 06:44 AM |
| cb model pro? any one try it? | grahamshere | General CAM Discussion | 0 | 12-22-2007 02:04 AM |
| Bostomatic 3200 PLC Ladder diagram | javed08 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-16-2006 01:40 AM |
| Lincoln 3200 HD - a good buy? | damae | Welding, Brazing, Soldering, Sealing | 2 | 08-18-2005 01:59 PM |
