Old 04-23-2008, 08:23 AM
NIKITEC is on a distinguished road
Haas VF-2 Jog Handle Vibrations
Hi all!
I am a newbie in this great forum and in CNC machining in general and I need your help!
We have purchased a Haas VF-2 4 months ago and we have started doing some tests on it just last month.
A potential problem we encountered is that most of the time we use the jog handle to move the table or the z-axis the machine vibrates too much.
We have communicated with the Haas local dealer and they say that this is normal and happens because of the servo mechanism of the table, however when this happens we cannot even use an indicator to zero set a part.
Has anyone had a similar problem?
Any suggestions?
Thank you for your help!
Old 04-23-2008, 08:26 AM
cadman@teluspla is on a distinguished road
My VF-4 does the same thing when travel is set at .100/notch
Have you tried selecting the smallest increment of travel
Old 04-23-2008, 08:45 AM
flashno is on a distinguished road
I would say, yes, this is normal, because when using the handle, the motors are starting / stopping quickly. For indicating, use the jog lock feature for a smooth move along an axis.
Ed
Old 04-23-2008, 08:50 AM
I think this problem does no appear in smaller increments of travel, but still it is a problem because it makes jog handling completely unreliable in some increments of travel.
The local Haas dealer suggested that when the vibration starts switch instantly the jog handle to handle one of the 2 rest axes and the vibration stops for a while but then it starts again. Can that be normal?
Actually, we are afraid that the machine is not correctly set up with regard to the floor...
Old 04-23-2008, 09:01 AM
PBMW is on a distinguished road
Sounds like your servos are hunting. They need to be tuned. Have your Haas guy come look at it.
Old 04-23-2008, 09:04 AM
No, they said that it is normal...
Old 04-23-2008, 10:53 AM
Nickitec,
Your further description strikes me as not normal. Servo "hum" can be OK to a point, but if the machine is sitting idle, and you see movement on an indicator (if this is what you are saying), this is not right. Press the issue for a warranty service call.
Ed
Old 04-23-2008, 11:14 AM
fourperf is on a distinguished road
my vf 2 does the same thing when set to.100. Not a problem here
Old 04-23-2008, 04:24 PM
Well...it's your machine. And the warantee will be up in a couple of months. Then they can charge you to fix what they should have done under warantee.
Your call....
Old 04-23-2008, 05:51 PM
awesome83 is on a distinguished road
The rough jogging is normal, because of the quick accel/Decel at each increment. If you can hear/feel large vibrations when the machine is just sitting idle, the z axis's motor needs to have the filters adjusted. This is common due to new machines not having a counter balance, so the motor holds the head up. It is a very easy adjustment but may take a few tries to get it perfect.
Par 29 Z-Axis switches
There are 4 bits you can change to help this out, i will list them below. Only have one/two of these bits on at a time.
LOW PASS +1X 0 or 1
LOW PASS +2X 0 or 1
D FILTER X8 0 or 1
D FILTER X4 0 or 1
This should help and when you get it to sound good during idle, if you have a set right it will make jogging the z-axis better too.
Make sure that you can rapid, and jog nicely too.
Hope this helps.
  #11   Ban this user!
Old 04-23-2008, 08:12 PM
rlabonte18 is on a distinguished road
Yes the vibration is normal. it is different than other machine manufactures in the hand wheel mode because haas uses a different type of servo amp that doesn't respond like a fanuc. The bed does actually start and stop on each click of the handle wheel. using the jog buttons is a better alternative until you get close the part zero point. I don't remember the technicals of the amp but it does not deliver traditional (clean voltage to the servo motors) it is sent actually by duty cycle to recreate the correct signal to the motors.
  #12   Ban this user!
Old 05-16-2008, 05:19 AM
Thank you for your interest and help guys!
I will continue machining as such.
Anyway, our warranty expires in 7 months time so we still have time to check things...
eliminating vibrations turpija Mechanical Calculations/Engineering Design 101 10-23-2007 10:56 PM
Handle Jog Pendant stang5197 Haas Mills 9 06-24-2007 04:56 PM
Jog Handle Rudee Fadal 1 05-04-2007 10:33 PM
Newbe: how do I handle I/O jaredp DIY-CNC Router Table Machines 3 02-05-2007 05:39 PM
Knife Handle wjbzone WoodWorking 0 08-17-2005 11:10 AM
