Old 04-07-2008, 08:37 AM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
Machining EPS (Styrofoam)
What are the considerations when machining styrofoam or EPS?
How to get a good surface finish and clean up the mess?
What type of cutting tool is best?
Old 04-07-2008, 09:26 AM
cam1 is on a distinguished road
Hi: We use solid carbide 2 Flute, and use a vaccum cleaner mounted to the Z axis on the VMC. Easy to cut ,crank up the feeds and speeds to determine what works best.
We cut blue SM.
regards
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
cnc machining fastolds Employment Opportunity 0 03-29-2005 02:37 AM
One Hit Machining CRPDGAZ Hard and High Speed Machining 10 03-24-2004 01:52 AM
machining of wax turmite General Metal Working Machines 8 08-14-2003 06:26 PM
