Old 04-05-2008, 02:20 PM
thetrillionaire is on a distinguished road
increasing cycle times
Just for fun
The owner of the shop refuses to buy any new CNCs until we have cycle times that are at least 60% of our total on times for the machine. It's just not gonna happen when we're making less than 5 parts in a run. I've noticed that when holding down the tool release button this adds to the cycle time. So i was wondering if anyone else knew of some ways to "cheat" the cycle clock to add to it while doing setups, looking for tools, etc.
Old 04-05-2008, 11:06 PM
mgsanchez is on a distinguished road
I worked in a shop that did something similar to us. We also did short runs, 5 to 10 parts. Then I asked myself, self, how do I increase my cycle time? I guess I could make my parts take longer or shut the machine off when I wasn't making parts, but that wasn't right.
Then it dawned on me, how do I reduce my non cycle time? There is only two places to reduce non cycle time, programming and setup. Our machines had macros that no one used. I went home and started writing macros (parametric programs) to do a lot things that we always did, fly cutting parts, square plates, drilling holes, etc. By using these parametric programs, "programming" went down to less than a minute for some parts. Next was setup, I went to a dedicated tool drum so I did not have to "chase" so many tools. I hate chasing tooling! This cut my setup time in half. The other benefit of a dedicated tool drum is that I did not have to "dial in" my tools for every part (another time saver). I also kept my vise and fixture offsets documented so I did not have to edge find and/or indicate every part in.
After implementing these simple measures, we went from 200k/month to 610k/month in production. Our quality also improved, all in three short months. We all got raises and two brand new machines, one CNC mill and one CNC lathe.
And you know the best part, I did not have to work so hard anymore.
Hope this helps,
Mike
Old 04-07-2008, 12:54 AM
And that's what makes it so frustrating...
The programmers are uncooperative, they're too concerned about churning out programs that they could care less about the overall efficency. I sometimes have to spend extensive amounts of time editing just to make them work! I am in the worst position because for running the most veristle machine i have the greatest variety of setups. Need the whole table, rip down the 4 vises and the angle plate you have up. Run this weldment and you're never going to see it again. I can't get dedicated tools unless i wanted to buy the tools on my own (better get some holders while i'm at it).
I've gone to my supervisor to try to pitch ideas to help us.
"we should organize our fixtures to save time..."
"good idea, you can go ahead and do it, but make sure to keep these 2 machines working while you do it"
I don't have any plans to cheat the cycle, i already am the top producer in the shop. But i was curious what other people have noticed about what creates cycle run time
Old 04-07-2008, 08:13 PM
Bummer!
I sounds like they don't want to get better. That only leaves you with a couple of options, put up with it or find yourself a more progressive shop to work in. You just might get yourself a raise while you're at it!
Hope things work out for you
Old 04-08-2008, 11:57 AM
Haas_Apps is on a distinguished road
You could just turn the machine off whenever it is not being used.
Old 04-08-2008, 12:51 PM
Rekd's Avatar
Rekd is on a distinguished road
I think doctoring cycle times will do more harm than good if you get caught. Sounds like you should start by recording the time you're taking to get these programs to run, then show that to the boss. Once you get the programmers on board with you, THEN you can start looking at cycle times.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-09-2008, 11:03 AM
glovebox20's Avatar
glovebox20 is on a distinguished road
I to worked at a shop like you have decribe.
I was "just an opertor" but when it came to make parts effiectly for a production run, the shop expected me to reprogram to G-code by hand because the guy who used Gibbis didn't know what he was doing and they did not want me to learn Gibbs. After Five years of this B.S., I decied to to go to a different shop which did lower tolance work but payed me the same and couldn't be happer. I do wish some times I was still at the other shop, But I did not have a faimly to support so it made it hard to put up with the B.S.
Sounds like you eather need to learn to not let these things bother you and put up with the B.S., or find another place to work, even if it's not metal working.
That's my two cents
glovebox20
Need help with Titanium cycle times!!! HAMMER66 General Metalwork Discussion 7 02-18-2008 08:53 AM
Hard Times ? Switcher CNCzone Club House 1 02-26-2007 10:09 AM
Extracting cycle times from FANUC OT swilly Fanuc 5 12-30-2006 04:19 PM
Extracting cycle times from FANUC OT swilly General CNC (Mill and Lathe) Control Software (NC) 0 12-13-2006 07:17 AM
Max Tapping speeds/increasing cycle time jderou General Metalwork Discussion 7 12-23-2005 07:51 AM
