| with error you get ? maybe you doesn`t have rotation ? typical use of G68: Code: G59 G00 G90 X0 Y0 Z0 M98 P1 ( some shape ) G90 G0 X0 Y0 G68 R60 ( optionally X and Y ) M98 P1 ( some shape ) G69 G90 G0 X0 Y0 M30 |
| We do have rotation & scaling and parameter is turned on I managed to get rid of the alarms however when the program is run it loops around twice in the same location, I have missed something % O00091 (GRIZZLEY) T4 M06 (.5 HANITA) G54 G90 G00 X0. Y0. M88 S2250 M03 G43 H04 Z1. M08 M98 P93 L2 G00 Z2. M09 M89 G91 G28 Z0 G90 M30 093 G91 G68 R45 G90 M98 P1 G90 G00 X0 Y0 G00 X4.882 Y-0.3155 G90 G42 G01 X5.5908 Y0.25 D04 F10. G01 X5.591 Y1.3 F20. G03 X5.316 Y1.575 R0.275 G01 X5.157 G03 X4.882 Y1.3 R0.275 G01 Y-1.3 G03 X5.157 Y-1.575 R0.275 G01 X5.316 G03 X5.591 Y-1.3 R0.275 G01 Y0. G00 Z0.5 G40 G01 X5. Y0.5 G90 G00 X0.0 Y0.0 M99 |
| I'm also having an issue with Mastercam X2 and a VF-3: we're using the X2 haas post, G68 incremental is enabled. When we first load the program, we'll get a line like: G90 Xxx Yyy G68 X.0 Y0. G91 R-72. Haas doesn't like this and throws a "multiple code" error. I can understand that, it doesn't like the G90 and G91 in the same line. If I split the block at the G68, we wind up with very strange tool paths, rapids with some details in the cycle being skipped over and others being "cut" twice. Is this a post problem, operator error, or maybe parameters in the machine? |
| I use the G68 a lot and the following works for me. Put it in a line by itself. Also check out your parameters/settings. In my case, the part is rotated a positive 28 degrees from 0 degrees. It is in the X Y plane and is in inches. The last line is the first move for some face milling. M06T1 M08 M88 (through spindle coolant) G00 G90 G154 P1 X0. Y-1.5 S1200 M03 G43 H01 Z2.72 G68 G17 X0. Y0. R28. G01 Y-3.5 F30. |
| rotate on axis A | tonyas | Mach Software (ArtSoft software) | 0 | 01-03-2008 04:20 AM |
| Rotate head | SPEEDRE | Benchtop Machines | 3 | 12-23-2007 12:44 PM |
| TM 1 turret rotate fault | f1jdm | Haas Mills | 4 | 11-28-2007 03:00 PM |
| V2007 Rotate | TZ250 | BobCad-Cam | 5 | 10-14-2007 12:39 PM |
| Rotate and copy | bdrmachine | Solidworks | 6 | 02-02-2007 09:56 PM |
