Hey guys First time on the site. Already have learned a few new things.. I do need some help. I have a tm-2 that came from the factory without the 4th axis pre wire. I bought a used brushless 210 rotary table and need it up and running. I beleave I can find a servo amp and cables to make this work. There are 2 wires i beleave i need. A short wire that feeds info to the amp from a computer board above ,and the wire assembly going out of the amp to power the servo, this wire is attatched to the machine with a female pin connector facing outside. the 210 already has the long wire with the male pin connector on it ready to go. I am assuming I can get these wires from haas. My main question is. Do I have to pay to set setup my parameters to accept the new hardwear? Or can these be changed by myself for free? And what parameters will I need to change? I called the techline and asked, I got some cockey guy on the phone that pretty much told me I need to spend $2100 in new haas parts to make my 210 table work. Then they will tell me how to set my parameters up. thanks for any help dave |
| Your going to need a code from Haas to turn the 4th axis on ... call your local dealer and see what they have to tell you .. and the cost is 4AXBLMM 4th-Axis Drive and Wiring only, for brushless-type rotary tables $2,095.00 suggested retail HRT210-CNCB 210 mm (8.27") Servo Rotary Table $7,995.00 suggested retail (this is what you bought used) |
| adding a 4th axis? | airbrush | Rockcliff Machine | 17 | 10-12-2007 05:00 PM |
| Adding a fan to the X3 | Antonyong | Benchtop Machines | 2 | 04-25-2007 11:19 PM |
| adding a stop | planescott | BobCad-Cam | 7 | 04-25-2007 07:56 PM |
| Adding a Joystick. | on7tim7 | Mach Mill | 0 | 01-10-2006 01:33 PM |
| Adding a 4th | Shizzlemah | Fadal | 5 | 12-01-2005 05:16 PM |
