Old 03-26-2008, 10:25 PM
jwknow is on a distinguished road
DNC from floppy drive
According to the manual I should be able to run a program directly from the "floppy disk". It says to press MDI then enter the program name and press MDI again.
I've tried several programs and several disks but I always get the same message "Cannot find file" or something similiar to that. I can upload these same files into the mill from the floppy, so I know that the disk is good and the controller can read them. It just won't allow me to run them from the floppy.
What am I I'm doing wrong? I'm following the manual step by step.
I also have the parameter and settings turned on for "DNC from floppy", as stated in the manual.
Any ideas?
JW
Old 03-26-2008, 11:34 PM
Gold Member
Ken_Shea is on a distinguished road
JW,
Haas files need to be files named staring with a"O" not zero
Here is a very simple example of the name, start charecheter and end charecter
O01234
N10 (PART - )
N20 (FILE - NEW FILE)
N30 (AUTHOR - DEFAULT USER)
N40 (GROUP - TOOLPATH GROUP #1)
N50 (POSTED - THURSDAY, MARCH 27, 2008 00:29)
N60 (CREATED - THURSDAY, MARCH 27, 2008 00:27)
N70 (SYSTEM- ONECNC-XR3 MILL 3D PROFESSIONAL - VERSION 10.25)
N80 (NOTES - NONE)
N90 G00 G40 G49 G80
N100 G00 G90 G54
N110 M05 G40 G80
N120 (.375 INCH 3/8 CARBIDE END MILL)
N130 T0
N140 M06
N150 M03 F0.0 S0
N160 G54
N170 G00 G43 Z300. H0 D0
N180 G00 X1.2419 Y0.6128 Z1.
N190 Z0.05
N200 G01 Z-0.2 F0.0
N210 X1.0777 Y0.4986
N220 G02 X1.1875 Y0. I-1.0777 J-0.4986
N230 X-1.1875 Y0. I-1.1875 J0.
N240 X1.0777 Y0.4986 I1.1875 J0.
N250 G01 X1.2711 Y0.5498
N260 G00 Z1.
N270 (END TOOL)
N280 M09
N290 G91 G28 Z0.
N300 G91 G28 X0. Y0. M05
N310 M30
Ken
Old 03-27-2008, 09:19 AM
JW,
My files all look like your sample.....percent sign on the first line....letter O with 5 numbers on the second line....etc. Program ends with percent sign. Still no luck.
I can load any of my programs "directly" into the mill with no problem but when I try to DNC them straight from the floppy, it won't read these same files.
JW
Old 03-02-2010, 06:29 PM
reinhartdr is on a distinguished road
Did you ever find out how to get that to work? I am having the same problem.
Old 03-02-2010, 08:32 PM
Well.....its been a couple years but I believe I solved the DNC problem by getting rid of the "extension" after my file name.
Example:
O12345 and NOT O12345.txt......or whatever extension a cad/cam program adds to your filename.
Haven't DNC'd from a floppy for a looooong time but I believe that is how I solved it.
Good Luck
JW
Old 03-11-2010, 08:39 AM
Yeah I figured it out. Here is what you have to do.
1. When saving your program make sure there is an O1111 or similar
example: Oxxxx
O1111
N01 GO M3 T1;
N02 G1
M30
2. IMPORTANT!!! When saving your program before putting on disk, save it to a no format. This means type in the save file name as to: O1111.
Thats it. Don't put .exe or .txt or .nc, just put a dot then a couple of spaces after it. This is what took me a while to figure out.
Example: Save as --- O1111.
3. Save that file to floppy disk
4. Put floppy into the machine, then go to programs list. Press F4. It will then read floppy and then say done reading directory.
5. Then press the MDI button. Type in your file name. For example: O1111
Then press the MDI/DNC button again. Your program should load and you should see the program. You are ready to press start cycle.
Note: I've noticed with mastercam X4 if the words in the parenthesis are too long at the beginning of the program there will be an error on the machine.
If you have any problems let me know.
Thanks,
Dave
Foolin around with an old floppy drive compuslave Stepper Motors and Drives 9 12-15-2007 10:17 AM
Yasnac floppy drive dewcnc Machine Problems, Solutions , Wireless DNC, serial port 0 03-19-2007 12:19 PM
Converting from Floppy Drive to USB TZ250 General Metal Working Machines 3 09-06-2006 12:55 PM
5 1/4 Floppy drive Stepper Motors High Seas Stepper Motors and Drives 9 03-17-2006 02:33 AM
IDE and floppy drive extension cable Karl_T Computers and Networking 4 11-17-2005 12:59 PM
