I am working on a project and have been tweaking the first step to death. I currently have the bulk of the program running with a spindle load of around 60-80 percent, but there are a few strokes that are running the spindle load at 175 percent for upwards of 5 seconds at a time. It is only a 7.5 horsepower head and at this stage it slows the spindle down. Now I recently read that my 7.5 horsepower head is only rated so at 200 percent spindle load for 30 seconds. So am I safe from damaging anything at 175 percent for 5 seconds? I have the spindle load setting on autofeed, so the feed I guess slows, but it is happening so fast I am not seeing it. Is there any way to have it slow down the feed automatically so that you never go above, say, 130 percent? Someone please explain this so I am not afraid to push this thing hard. What spindle loads do you guys run at? Thanks. |
| Unless you have entered a maximum spindle load your autofeed will not kick in. The load settings are CURRENT COMMANDS and then page down until you get to the page with a column for spindle load. Put in whatever you want to be the maximum for each tool; I use 120%. Now you should certainly see the feed back off when you hit the high load regions in the cut. I think you are pretty safe running 175% for 5 seconds and there is no reason why you should set your maximum load lower than this. I only use 120% because I am conservative.
| servo and spindle drive regen load resistors | daleman | Haas Mills | 27 | 12-04-2007 11:28 AM |
| Hurco VM1 Spindle Load Monitor | MidFloridaTech | HURCO | 1 | 11-22-2007 12:15 PM |
| Spindle accel/decel load | fpworks | Fadal | 2 | 10-30-2006 09:09 AM |
| TAIG spindle speeds and a load meter question | Smertrios | Taig Mills & Lathes | 2 | 04-26-2006 04:34 PM |
| Spindle load meter ? | Ken_Shea | Haas Mills | 1 | 10-10-2004 10:21 PM |
