Old 03-26-2008, 09:35 AM
l u k e's Avatar
l u k e is on a distinguished road
Garage door height and VF2
I did some checking and found that the Side Mount Tool Changer on the VF2 is 94".
My garage door is 94.5" (I can get 95" by removing the trim.) So, I need to figure out how to "slide" the machine into the shop. I know for a fact that the garage door header is non-bearing so notching (if completely necessary) would be an option.
I was thinking that I could build a dolly of some sort that I could lift the mill a 1/4" or so off the ground. Just enough to make it mobile!
Are the 2 slots in the front of the mill for a fork lift?
http://www.haascnc.com/VMC_specs.asp...0#VMCTreeModel
The HAAS rep didn't know with conviction weather or not the height of the tool changer was my only height concern. Can the other components be removed to clear my door?
Old 03-26-2008, 10:13 AM
HAILINHAAS is on a distinguished road
You probably could remove the SMTC sheet metal and get another two inches
Old 03-26-2008, 10:37 AM
Originally Posted by l u k e View Post
.....I was thinking that I could build a dolly of some sort that I could lift the mill a 1/4" or so off the ground. Just enough to make it mobile!...
Are you sliding on a firm surface, concrete or black top?
Lay some strips of 1/4" thick UHMW polyethylene on the floor and just slide the machine along these.
About the only thing you might need to do is lift the machine up and chamfer the corners of the 'feet' on the machine. You will need this so they do not tend to cut into the plastic.
These slides and two good Come-Alongs to anchor points drilled into the floor at the back of the garage and you will slide it in as easy as can be.
EDIT: Also to get a bit more height without notching: If the garage walls are not lined so you can get at the bottom plate just detach this from the foundation and jack the entire wall up an inch or so. You can probably do this with a couple of pole jacks under the door header.
I am pretty confident both these ideas will work....because I have done both.
Old 03-26-2008, 11:32 AM
l u k e's Avatar
I do have concrete inside and out side the shop.
Jacking up the shop is not possible.
My first thought was to sit the machine on a 1/2" thick piece of plywood, throw down sand on the concrete and drag it in that way.
Old 03-26-2008, 05:38 PM
jmcglynn is on a distinguished road
Haas has instructions for getting it through doors down to 72" (I think) on the VF2. My door is 84", they are delivering my VF2 on Friday.
Old 03-26-2008, 06:01 PM
.....My first thought was to sit the machine on a 1/2" thick piece of plywood, throw down sand on the concrete and drag it in that way.
You will find the UHMW is much more slippy than the sand under plywood.
Old 03-26-2008, 06:12 PM
Not necessary... Talk to your HFO, they have instructions on which parts to remove in order to get each machine through various sized doors.
Old 03-27-2008, 05:37 AM
Kiwi is on a distinguished road
If your concrete floor is reasonable smooth you should be able to slide on the concrete.
22 gauge sheet metal will help.
I dragged my 9000lb machine centre like this.
ID:	56455   Click image for larger version
ID:	56456   Click image for larger version
Old 03-27-2008, 07:12 AM
mike cncmachine is on a distinguished road
I moved mine in with a pallet jack
Old 03-27-2008, 08:49 AM
l u k e's Avatar
Originally Posted by Kiwi View Post
If your concrete floor is reasonable smooth you should be able to side on the concrete.
Now that's tight! Pretty close to what I'm looking at.
  #11   Ban this user!
Old 03-27-2008, 08:51 AM
l u k e's Avatar
I did and they offered no such info. All I got was a drawing showing the height of the tool changer.
  #12   Ban this user!
Old 03-27-2008, 08:52 AM
l u k e's Avatar
http://www.haascnc.com/VMC_MODEL_20IN.asp#VMCTreeModel
Screw Drive garage door opener Kevin McFarl DIY-CNC Router Table Machines 22 01-17-2009 04:34 PM
Did you start your business in your garage? katiebo General Metalwork Discussion 17 05-31-2008 01:23 PM
Torch Height Control / Capacitive Height Control ahlbebuck Open Source Controller Boards 0 11-27-2006 01:32 PM
Garage Door CNC Gantry Router DougMorency DIY-CNC Router Table Machines 3 02-20-2006 01:57 PM
4020 move, minimum height door??? morestuff Fadal 1 08-17-2004 10:50 PM
