I am doing rigid tapping for the first time on Haas Mini Mill Material: Aluminum 6061-T6 Tap size: #10-32 Tap: HSS Spiral Flute Tap (Greenfield) Full thread depth required: 0.5” It is a blind hole drilled to 1.2” depth I tried with 500 rpm (Too low I presume). The chips get entangled in the tap and are not thrown away by the coolant. I tried going 0.25” full thread depth only. What is the recommended rpm for this tap size? By using higher rpm and increasing the R plane value from .1 to .4 will help? Can I go the depth of 0.75” in one shot? (this will give the full thread depth of 0.5”) Thanks, R. Rossey |
| A couple of questions first. Blind holes like a spirol flute tap becaue the chips come out the top. Thru holes like a spirol tip tap because it pushed the chip out the bottom I like form taps because there are no chips and you can go faster. Of course the drill size is not the same... That said, I tap at about 1500rpm on my mini. Everything from 000/120 to 3/8-16 I usually leave about .05 at the bottom of the hole on a form tap for clearance |
| I do all the time. I have a part that I do on my lathe that has a 5/16-18 thd. 1.25 deep. I form tap it at 2000 rpm. I do these on my SL10 Haas with no issues Just be sure to look in the machinerys handbook for the correct tap drill. It is NOT the same as a regular cut tap. It is a significantly larger drill. Use th ewrong drill and you'll break taps |
| I have several parts that we tap 10-32 holes that deep and a little deeper.The one thing I would do is up the rpm to 1500.As for it being a blind hole you have plenty of extra depth,so no problem there,same goes for the spiral taps.Your r value dosn't efect anything as far as the tapping,that's just a start point. The one thing we do that may efect it, would be that we modified the flexable coolant line so that it sprays a very small tight steam of coolant staight into the hole as it's tapping,this may help with chips. Hope this helps |
| Form tapping works very well in aluminum. If the coolant proves inadequate we will turn off the coolant and brush some "PRO-TAP" on the tap. You can even put the PRO-TAP in a hand pump oil can and squirt it directly into the hole. P.S. Remember you can only rigid tap up to 2000 rpm on most HAAS mills. Also, check setting #130 "tap retract speed" I like to set this to "1" when tapping shallow holes at high RPM. Based on discussions I've had with HAAS techs I believe this reduces possible synchronization error (not 100% sure if that's true, but just a quark I have). |
Have you watched how fast the spindle gets to when tapping. I set the speed at 1000 rpm and rarely does it reach that before it stops and backs out. Setting a higher speed would be no faster.
#11
| I guess the Robodrill has a small spindle; less rotating mass so it can accelerate faster. There is quite a difference between tapping cycle times on our Super Minimills versus a VF2 with the same program.
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Haas mini mill | pyroracing85 | Haas Mills | 11 | 05-11-2008 07:33 PM |
| Newbie- Haas rigid tapping help | ShaggyVW | Haas Mills | 6 | 03-14-2008 09:09 AM |
| Mini Mill can it repeat rigid tap? | Loading | Haas Mills | 7 | 09-11-2007 09:26 PM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
