Old 03-14-2008, 07:39 AM
teal854t is on a distinguished road
Help, VF OE: alarm #194
When we home the machine, it comes up with alarm #194, B zero return margin too small. We swap cable, indexer unit and still the same. Sometimes jog the indexer for 360 degrees or so and it homes fine. Could it be from the controller board?
Old 03-14-2008, 09:19 AM
Probably a dirty microswitch sticking or a chip on a proximity detector.
Old 03-14-2008, 10:20 AM
If the proximity switch is bad why does it still happen after changing it with another indexer unit and cable?
Old 03-14-2008, 10:32 AM
JoBwan's Avatar
JoBwan is on a distinguished road
Alarm 194
teal854t,
Call your HFO. They may be able to talk you thru a parameter setting to fine tune the indexer to the machine. Just a thought??
Just a good ol' boy, never meanin' no harm.
Joe
Old 03-17-2008, 12:18 PM
Fixed the #194
Haas tech. came over and adjusted the grid shift parameter for B axis. So far so good.
Thanks for all the help.
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- Getting a 071 alarm, willow sanchez General CNC (Mill and Lathe) Control Software (NC) 3 01-25-2008 06:26 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
alarm 160 on vf4 markct Haas Mills 4 06-15-2007 06:31 PM
205 p/s alarm bink Fanuc 0 12-08-2006 09:04 PM
