Old 03-14-2008, 12:42 AM
chad123 is on a distinguished road
Hi all, Tool diameter offset question.
Hi, I have been teaching myself how to use a friends VF3 and have some questions about tool diameter offsets.
I was doing a test piece for a bearing seat. I am using the tool probe to set the length and diameter and this seems to be working because things are turning out exactly as designed. Now my question is how can I fudge the tool offset by .0005 to give me a little room for the bearing.
I have tried to add and subtract up to .004 from the diameter of the measured value with no difference in the cut. I have also tried the same with the wear and still can't get it to fine tune my hole.
Now I understand that I should just program it a little bigger but some times it is not as easy as just bumping the tool diameter a smige and re running the hole for a smooth fit.
Any suggestions?
thanks,
Chad
Old 03-14-2008, 12:59 AM
dcoupar's Avatar
If you put a G41 Dnn or G42 Dnn in your program, the subsequent moves will be compensated left or right by the value stored in Dnn. Since I don't know what your program looks like... imagine milling a 2.000 circle centered at X0, Y0 with a 1.000 diameter end mill, and D01 set to 0.000.
Measure the bore after the 1st run. If it's undersize, put a - (minus) comp value in D01.
O0100 (INTERPOLATE 2.0 DIA W/ 1.0 EM)
N005 T01 M06
N010 G00 G54 X0 Y0 S2500 M03
N015 G43 Z0.1 H01
N020 G01 Z-0.5 F20.0 M08
N025 G41 X0.5 D01 F5.0
N030 G03 I-0.5
N035 G01 G40 X0
N040 G00 Z0.1 M09
N045 G53 Y0 Z0
N050 M30
Old 03-14-2008, 02:02 AM
Ok, that helps. I will play with that.
Thanks.
Chad
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 09:54 AM
tool offset question WarrenW SheetCam 7 04-29-2006 01:43 AM
question about Yasnac tool offset in the Z DDuley Machine Problems, Solutions , Wireless DNC, serial port 0 02-18-2006 07:23 PM
G43 Tool Offset question sbrunton LinuxCNC (formerly EMC2) 3 07-20-2005 10:53 PM
Any Info On Tool Diameter Compensation? FLUTE HEAD TurboCNC 13 10-26-2004 05:02 PM
