Old 03-12-2008, 12:01 PM
ShaggyVW is on a distinguished road
Exclamation Haas rigid tapping help
Hi all, Im not new to cnc but have been machining for 15 years manually. I got started in CNC full time 5 months ago and I was wondering if someone could post a sample code for rigid tapping or point me to where I could find some sample code. I use powermill ver 8 and I want to compare the code it is outputting for the haas with some real world code that has been used before on haas machines. I have 10, 1/2-13 tapped holes I need to machine that are 1" deep inside a 1.25" deep pocket. Our company has never rigid tapped in a cnc before so Im the newbie who gets to figure it out. Any help would be very much appreciated. You can also email me at sgrigsby@omniforge.comThe haas machine is a VM6, we just installed it 3 months ago and are attempting to rigid tap.
Old 03-12-2008, 08:10 PM
kurt66 is on a distinguished road
the format for rigid tapping would look like this
G84 X****. Y****. Z****. R****. F**.
in order for this to work you have to get the feed and spindle speed right.
rpm/tpi will give you the feed rate.
for example: if the spindle is turning 65 rpm and you want 13 threads per inch you would divide 65 by 13. the feed would be 5ipm
the r is just a retract plane, make sure it clears the rest of the job.
any ofther questions just ask
Old 03-13-2008, 01:25 AM
And make sure you have Rigid Tapping turned on and Repeat Rigid Tapping. Scan through the threads in the Haas mill forum this has been discussed at length several times.
Old 03-13-2008, 02:40 AM
gsrmmeza is on a distinguished road
O1( HAAS TAPPING PROGRAM )
N1( X0 Y0 CENTER Z0 TOP OF PART )
N2( T1 .125 CENTER DRILL )
N3( T2 .4219 DRILL )
N4( T3 1/2-13 CUT TAP SPIRAL FLUTE )
N5G0G17G40G80G90
N6M6T1
N7M3S3200
N8X0Y0G54
N9G43H1Z.1M8
N10G81X0Y0Z-.075R.1F6.4
N11G80
N12G0Z3.
N13M5
N14M9
N15G49Z0
N16M1
N17G0G17G40G80G90
N18M6T2
N19M3S948
N20X0Y0G54
N21G43H2Z.1M8
N22G83X0Y0Z-1.25R.1Q.075F1.94
N23G80
N24G0Z3.
N25M5
N26M9
N27G49Z0
N28M1
N29G0G17G40G80G90
N30M6T3
N31M3S100
N32X0Y0G54
N33G43H3Z.2M8
N34G84X0Y0Z-1.R.2F7.69
N35G80
N36G0Z3.
N37M5
N38M9
N39X0Y0G59
N40G49Z0
N41M1
N42G0G17G40G80G90
N43M6T1
N44M30
G54 IS THE PART HOME. THE G59 ON LINE N39
IS A FIXTURE OFFSET I SET WHERE I WANT TO
CHANGE OUT THE PART. ENJOY
Old 03-13-2008, 06:43 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Turning Rigid Tapping On During Trial Period
I am am a newbie to CNC and recently purchased a HAAS TM-1P. HAAS offers a trial period 100 hours I think for Rigid Tapping. I have attached a copy of a little check sheet that may be helpful to you in determining if Rigid Tapping is properly turned on in your control whether you are using the trial demo or just making sure you have all the parameters and settings turned on in you machine. So far I have only used rigid tapping a few times but it has worked like a dream for me. If you are using the Demo/Trial mode make sure to reverse the steps and turn Rigid Tapping off when you are done with the job to save your demo hours. I intend to purchase the rigid tapping option when the demo runs out as it makes tapping a no brainer even for a newbie like me.
Like Geof has already stated it has been discussed in several threads, but thought you might want to take a look at my little cheat sheet just for grins.
John
Old 03-13-2008, 06:56 AM
Just wanted to say "THANKS" to everyone who has posted and emailed me. You guys have been great! I hope I will be able to help some of you in return one of these days.
Old 03-14-2008, 09:09 AM
cnc-king's Avatar
cnc-king is on a distinguished road
take a look at haas's web site they have some very good programming info there
If you can ENVISION it I can make it
Tags
haas, tapping
Rigid tapping Ken_Shea General Metalwork Discussion 7 12-20-2008 11:35 AM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Very rigid tapping Vern Smith Haas Mills 55 06-14-2007 05:52 PM
Rigid Tapping Teps71 Milltronics 31 10-29-2006 11:22 PM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
