Old 03-05-2008, 08:12 AM
fourperf is on a distinguished road
roughness in spindle
Hey guys. Last night I replaced the ruby ball on my probe (they are very delicate I found out). When I was getting the new one set up with a dial indicator I noticed a little hitch, bump or roughness in one spot as the spindle rotated. If am going make a service call but am super stressed out since it is a 3 week old machine not running that much. Could it be a belt or something else other than a blown up spindle? It would be ironic to get a machine that had a spindle problem as one of the things I was concerned about on my old machine (fadal) was all the spindle problems they are having. Should I not use it until they service guys come check it out?
thanks
mark
VF2
Old 03-05-2008, 10:00 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Is it mechanical or magnetic? In other words: is it a grinding feeling or just a spot the spindle 'likes' to be in?
While trying to troubleshoot my original, ailing vector drive, I learned that the vector drive carefully regulates its output when the spindle is running. When it's supposed to be off, there are also idle voltages coming out that are not always equal. You can sometimes feel that as a spot the spindle tends to favor.
I guess a way to test would be to e-stop the machine. That cuts power to the vector drive. If it still has that feeling, it ain't electronics. Write it down though. And get it documented. The VF-2 comes with a 1 year warranty, right?
Greg
Old 03-05-2008, 10:14 AM
thanks Greg, I am going to check it now
Mark
Old 03-05-2008, 10:57 AM
It seems to be mechanical, like a roughness in the bearing. Oh ****. I will let you know after the tech has come
Old 03-05-2008, 12:13 PM
Originally Posted by fourperf View Post
...... Should I not use it until they service guys come check it out?
thanks
mark
VF2
This is the wisest approach I think.
You have not by any chance crashed it? Particularly with the spindle stationary.
Old 03-05-2008, 05:05 PM
never crashed. The tech has been here all day. It is the belt riding down the pulley and rubbing. Apparently all you can do is shim the motor. He had been working all day on it and its still not right. I lost a whole day but at least its not the spindle.
Mark
Old 03-05-2008, 07:03 PM
.......but at least its not the spindle.
Mark
Deep sigh of relief, yes?
Old 03-05-2008, 07:43 PM
Very deep sigh of relief. They just shimmed the motor. The belt sitll rides a bit on the lip of the rear pulley. They told me that they all do that. It is way less than beforew and the spindle is smooth again.
Mark
Old 03-06-2008, 08:53 AM
HAILINHAAS is on a distinguished road
motor sits on rubber isolators .. depending how you tightened down the motor .. hopefully evenly
Old 03-06-2008, 09:36 AM
they shimmed the motor, I am not sure it was even on both sides. It took something like 5hrs. I hope its fine.
mark
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
Just had my spindle reground by Spindle Grinding Service! Edster Fadal 30 06-16-2006 10:48 PM
