OK. I have worked in a machine shop for over 20 years. I am good with computers and assumed this would be a simple transition. This is kicking my butt!! I got the WIPS have figured out how to set x and y work offsets, but the Z axis is never right whenever I try simple intuitive programs. I just want to write the number 3 in a pc of aluminum.....thats all! When I hit cycle start, it grabs the ball endmill, goes to the center of the work pc, but the tool is 4+ inches above the surface. How do I set Z0 at the top of the aluminum?!? Next, the warm up program. I try to run it and it tells me I am in the wrong mode. What keys do I have to hit to run the damn warmup program?!? Finally, the spindle probe. I used it all day yesterday, playing around, running the automatic (Intuitive Programming) programs for touching off. I loved the one for a raised square boss (the one I used for my aluminum that was supposed to get a 3 egraved on it) and I it worked beautifully all day. Today, I ran the exact same probe subroutine because I moved the aluminum in the vice and instead of going down in Z to find the top of the part, it never stopped going down in Z. CRUNCH!!!! The spindle probe didn't remotely turn on and there goes my new 6mm ruby ball!!! Has anyone ever seen this or know what could have caused it? We were welding aluminum in the shop and I am wondering if the high frequency caused it. Can anyone please help me get started? So far it has been like getting kicked in the shins. I just need a little help getting the ball rolling. Thanks in advance. |
| 080213-1727 EST USA Just a quick note. Assuming you are in either HAAS or Fanuc mode, and that the work coordinate system is G54, I believe it will be this by default on newer machines, then on the offset page and for G54 there is a Z value that controls your Z 0 position. However, this is inter-related with tool length in the offset page, and the G52 Z value. . |
I appreciate all of the offers for help. I will be taking some of you up on your offers, but first let me give everyone an update to the story. I received a call at work today from a (I assume my) Haas factory outlet. They were referring to this post! They had put together this story along with the phone call I had placed to service over the probe malfunction (or mal-button on my part....who knows!) and offered to send a technician by to go over the controls with me and get me over the hump. Hows that for service!?! That is why you buy American! John, Tony.....I will be in touch. Haas Factory Outlet......Thank you immensely! |
61SedanMan, I know what you mean. My local HAAS Factory Outlet has been really nice to me and offered help any time I called them. Mike the technician that did the install on my machine was SUPER. He said he would not leave until I was completely satisfied. Yes, Buy America. The job you save may be your own. John |
#10
I am the AE from hfo anaheim I read here weekly or daily any help you need thats what we are here for when you decide to get fancy with the probe and need some help let me know lately I have been using the probe to do in process inspection later Bob A HFO Anaheim |
#11
| Ok. Here is an update from today's visit from a different HFO technician. Would you believe he beat me to work?!? I actually made chips today that weren't ruby! Let me give you a rundown on todays activities. First off, I was trying to run the spindle warm up program in the wrong mode. The laminated quick start guide Haas includes in the control notebook that comes with the machine doesn't mention the part about being in MEM mode to run programs. Secondly, I had setup the spindle probe as one tool number and then tried to run it from another. I hadn't filled the tool magazine and being afraid really to leave it (the probe) in the magazine, I had taken it out and tried to run the part probe subroutine with it loaded in a different tool number. The offsets were, obviously, saved under the tool number I calibrated the machine with. Makes perfect sense in retrospect, but there is no way I could have guessed that and it was only explained to me by today's technician. I still think that it should have cut the probe on and the machine fault out or stop when it touched in z, but I can see where offsets could have confused the subroutine. Anyway, problem solved. And I quit using intuitive and started using the VQC probing and cutting subroutines. MUCH BETTER!!! I was able to write my name (Greg) 3 times in 3 scales, cut a slot and drill and tap 5 1/4-20 holes!!!! I know this is elementary to most of you, but the point is that I was able to set the top of my aluminum as Z0!!!! I now understand how to compile, test and execute VQC template subroutines!!! One problem I did notice with the pre-programed templates is that if you are cutting a rectangular pocket there is no 'peck-plunge', if you will, on the z depth before you get to full depth (ie. if it is a 1.5" deep pocket, you should take that in several steps). I wonder if there is a VQC template for that already? I see a forum here that I will have to check out on VQC. Anyway, thanks again for the overwhelming support to get a 'green-bean' over his hump. Cheers! |
#12
| I'm not sure if you knew this or not but I learned the hard way. ![]() I too doinked the probe tip the first night with my VF-2. I was getting used to using the handwheel to select menus. I had jumped to a different mode and thought Hand Jog had deactivated. It didn't. I got to the menus, spun the handwheel and 'crack'. ![]() Anyway, on to the point: I was looking through the McMaster Carr website and discovered that they sell replacement (non-Renishaw) ruby tips for a whole heck-of-a lot less than Renishaw. I paid over $100 from the HFO but the one in McMaster is under $40. Of course that's worthless knowledge now. Unless something goes wrong in the machine, I'll never need to buy another one.
__________________ Greg |
| well now that i have it im lost..... | pulsar110 | Laser Engraving & Cutting Machines | 14 | 11-25-2007 11:50 PM |
| Lost in CNC World! | ImageMetal | Commercial CNC Wood Routers | 0 | 06-13-2007 02:51 PM |
| Im lost, where do I go from here??? | ifttinker | Syil Products | 8 | 01-15-2007 06:45 PM |
| I'm Lost & Frustrated - Need Help | Hack | Stepper Motors and Drives | 14 | 12-09-2004 03:45 PM |
| Man, I'm lost | mrcodewiz | Benchtop Machines | 5 | 06-14-2004 03:51 PM |
