Old 02-11-2008, 11:58 PM
frogger is on a distinguished road
Speeds and Feeds
I have been machining Aluminum only for the past 12 months. I've just thrown a block of mild steel in and drawn a blank on speeds and feeds. I'm roughing with a 5/16 Ball End Mill on a VF1, any ideas would be cool,
Cheers,
Frog Man
Old 02-12-2008, 01:49 AM
DSL PWR is on a distinguished road
Carbide or HSS?
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 02-12-2008, 03:25 AM
Sorry,
Carbide
Old 02-12-2008, 05:49 AM
mrainey is on a distinguished road
Good info here.
http://www.niagaracutter.com/techinfo/index.html
Software For Metalworking
http://closetolerancesoftware.com
Old 02-12-2008, 04:18 PM
Thanks MRainy,
I threw some data into the mix and came up with about the numbers I am using.
As I mentioned before, I machine mostly Alluminium and usually the same parts so the numbers just come out of my head really. This is the first plane carbon steel we've machined on our VF1 and the first steel I've machined for years. At the moment I'm running..
2500RPM
Feed Rate 400mm/M or 15.7"/M (sorry about the metric)
Depth of cut 1mm 0.04"
step over 3mm 0.12"
Carbide Ball nose 8mm 5/16" Diameter (tools hanging out 40mm 1.5")
Does anyone have comments on this? Does it seem close to what you would use or off the mark? It seems a little slow to me and I also have some vibration.
See set up,
Frog
Old 02-12-2008, 04:49 PM
You could probably take both rpm and feed up quite a bit. It is a bit of a play off between how fast you want to remove metal and how long you want the tool to last. At your current speed and feed your tool is probably going to last a long time but is removing metal slowly; if you double the rpm and tripled the feed you will remove metal faster but the tool will not last as long; exactly how long is difficult to predict, but it is likely the extra cost in tools is more than compensated for by the time saving in machining.
It is possible you could take the speed up even higher than double, take the feed up to four or five times and use an air blast rather than coolant for much faster removal with good tool life.
Old 02-12-2008, 08:44 PM
At a .040 cut depth the cut width is only .209, so you're under 140 SFM, which is quite low.
On the other hand, your tool is hanging out pretty far, so the potential for cranking up speeds and feeds might be somewhat limited.
The only way to find out is to give it a try.
Old 02-15-2008, 01:23 AM
KevinWilkins's Avatar
KevinWilkins is on a distinguished road
There's lots of different types of alu, check which grade you are using and contact the maker of your cutter for proper feeds and speeds for the cutter. Works every time!
www.wilkins-knives.com
Old 02-15-2008, 09:55 AM
Oldmanandhistoy is on a distinguished road
Originally Posted by mrainey View Post
Good info here.
Respect
Frogger,
I would highly recommend having at look at this excellent software ME Consultant Professional from here http://www.mrainey.freeservers.com/
John
Old 02-19-2008, 01:24 PM
Thanks for all the help.
  #11   Ban this user!
Old 02-19-2008, 08:24 PM
rickyt is on a distinguished road
You can also go into the Help/Cal menu and page down to the speed and feeds cal. I used it the other day with some D2 on my TM-2 and it was pretty close. I like that you can put in the chip/tooth, rpm, sfm and tool dia. then BAM there it is.
  #12   Ban this user!
Old 02-23-2008, 11:57 AM
littlerobb is on a distinguished road
feeds and speeds
I push my machines to the absolute limit. Replacing tooling is a cheap way to make parts efficiently. I have a vf3 that I run a one inch e.m. 120 inches a minute in 6061, speeds and feeds are something you feel with your forehead, know what I mean?
Robert
Speeds And Feeds John H General Metalwork Discussion 10 12-08-2008 09:10 PM
Speeds and Feeds CLP CORP. WoodWorking 16 12-07-2007 12:38 PM
feeds and speeds JpBinc General Metalwork Discussion 4 10-03-2006 12:48 AM
feeds and speeds rchprks General Metalwork Discussion 2 07-17-2006 06:48 PM
feeds and speeds lito General Metalwork Discussion 4 03-14-2005 07:58 AM
