Old 02-08-2008, 08:14 AM
mgb1974 is on a distinguished road
Renishaw Probe system basic questions
We have a VF2 that came with the factory twin probe wire system. OTS tool setter and MP40-2 Touch Probe.
Trying to get the basic operation of it. I have downloaded the powerpoints from HAAS about using VQC with the probe.
Questions is how does the probe output data? On the Controller screen? What values does it output (T values like cmm or coordinate values?)
I seen how to use VQC for tool setting length but not diameter. How do you program to input tool diameter?
Any other comments would be appreciated. Still working through figuring it out.
Matt
Old 02-08-2008, 01:00 PM
guypb is on a distinguished road
Even though the Haas comes with VQC, it actually has a complete and very capable set of Renishaw Inspection Plus macros installed. This allows you to update work & tool offsets, as well as print reports etc. You can write values to macro variables etc. If you want I can send you the manual. The tool setting probe also allows you to set length &/or diameter and do in cycle tool breakage detection - powerful stuff.
Contact Brent at brent@machinetoolprobe.com - he'll tell you how to get data out of your Haas probe onto professional looking inspection reports!
Old 02-08-2008, 10:15 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Probing
Hi Matt,
I am a newbie and just purchased a new HAAS TM-1P with the Renishaw Wireless Probing system. WIPS.
I am just getting acquainted with the probing system and I made a little document that describes in my words what each of the probing cycles does and how to accomplish the probing tasks. The on screen information is not that great. I have not proofed it as I just made it today.
I realize my system is not the same as yours but this may be of some help. I intend to do the same thing with the tool setter.
On my machine you can run the Renishaw probe software from VQC or the Intutive programming software. It has the capability to save you a ton of time in your setups.
Hope this is some help.
John
File Type: doc Renishaw Wireless Probe Operations.doc‎ (54.0 KB, 399 views)
Old 02-10-2008, 10:56 AM
pmurdock is on a distinguished road
Hey there.. Interestingly enough I bought the WIPS option as well.. Just a heads up - you cannot calibrate the work probe using VQC you have to use the IPS calibration code. This is if your probe has a round Haas logo on it. I beat myself up trying to calibrate the darn thing using VQC but it never set the offsets correctly.
The other thing was when I tried to measure a tool length offset on the table probe it touched off on the tip and then turned on the spindle and tried to touch the sides of the probe. is it supposed to turn on a drill bit and rotate it and then touch of the table probe.. Seemed like that would destroy the table probe so I hit the E-stop just before it hit it.. thought maybe it was a bug in the code??
guypb - that inspection plus programming book would be handy to have.. Could you mail that to me via PM? I don't know why but I can't seem to find it anywhere.
cheers,
Paul
Old 02-10-2008, 02:02 PM
Probing
Hi Paul,
I am just a newbie to all this probing stuff so what I say may not be correct. I will let the guys that have some Renishaw WIPS probing experience offer corrections as necessary.
When you do tool offsets using the IQC (white screen) it not only sets the tool length but also determines the actual diameter of the tool. The spindle comes down until it touches the tool probe and then retracts and approaches again at a slower feed. Then it retracts slightly again and the spindle starts (but in a reverse direction - look at the rotation arrow on your screen) This allows the back edge of the cutting sufface to rub (not attempt to cut) the tool probe while checking the diameter of the tool. It will move the Y axis to place the tool in front of the probe at the depth you specified in the initial input screen then do a couple of touch offs. Then it will raise the tool above the tool probe and move to the Y axis so that the tool clears the tool probe appropriately and go to the depth specfied and probe the other side of the tool.
The only thing that really scares me is when the tool makes initial contact with the probe. The tool seems to hit the tool setter harder than necessary. Guess speed is what they are looking for and it doesn't hurt the tool probe.
The other thing I did when probing a ball mill was treat it like a drill so it would touch off the center of the ball mill instead of doing any type of an offset to measure the tips of the end mill. Maybe someone else can shed some light on this as I may not be doing that correctly.
If you use the VQC (black screen) it allows for different types of tool probing. You can just probe for the height of the tool (the spindle doesn't come on) or probe for the height and diameter (the spindle comes on and checks the tool diameter front and back using a Y axis jog) as well as other options listed in the templetes.
Hope some of the experienced users chime in and offer any tips and tricks about using the probing system.
John
Old 02-10-2008, 03:34 PM
That's interesting... I hadn't even considered that it might be spinning the tool in the reverse direction in order to avoid cutting. It would make sense though to increase the rigidity of the tool so that when touching off the probe you don't get any deflection.
So far I've thoroughly enjoyed using this probe though.. I have some big plans incorporating these macros into setups and even inspection reports. I'm trying to use a Lantronix WiPort (Serial to WiFi) module to enable me to connect via IP (using a virtual COM port on another computer) to control via DNC and gather serial report data.. certainly exciting what you can do with these machines.
cheers,
Paul
Old 02-10-2008, 04:57 PM
Vern Smith is on a distinguished road
The first touch on the tool setter is done at close to 10 IPM so it whacks the anvil pretty hard. If you look at the program in your MDI window you will see the Z feed rates called for.
Vern
Old 02-10-2008, 08:55 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
That's why I go into Handle-Feed and 'spin down' the feed rate to something slower.
But I don't think it's the impact we're feeling/sensing when it makes contact. It's the whack of the servos stopping. My VF-2 hammers the concrete pretty well when it's peck drilling.
I cut the feed rate (during probing) because I figure that the slower it approaches, the more accurate the touch-off will be.
What I didn't realize is that there are Quick Code screens for the probing (white ones). I've gotta' go take another look. I poke right past the white screens into VQC--I've never even looked at 'em.
Greg
Old 02-10-2008, 09:25 PM
If you use the VQC program that sets multiple tools it has to come down from Z0 (naturally) for each tool after the tool change. I think the 10 ipm plunge rate is to speed up the probing cycle, it's a long slow way from Z0 to -15 or so for 5 or 6 tools. The Renishaw also takes three whacks at the anvil, the last one at 1.8 ipm if memory serves me ( which it seldom does ) so I don't think accuracy suffers.
On my machine the white screens are part of the intuitive programming system. I've used it a little and have found it much less "intuitive" than VQC where the probing macros are concerned. Of course that could be due to operator idiosyncrasies.
I've gotten reliable rumors that Haas is going to dump VQC. They have already sold off the proprietary rights to a third party Internet educational company. My guess is this is their opening gambit into a controller based CAM system. Remember, for every machine replacement there are 5 or 10 software updates, every one a revenue generating event.
Vern
Old 02-11-2008, 08:21 AM
fourperf is on a distinguished road
not to hijack this thread but what variation do you guys see day to day on your offsets for your tooling. I have seen up to 4 tenths.
Mark
  #11   Ban this user!
Old 02-11-2008, 09:05 AM
I've had mine for a short time so don't have much of a data base. I have probed X & Y then run the table all over the place, come back and run the macros again with virtually no change. I did it 4 times in succession with the same results. The Z settings are another story. Leave the tool in the spindle and she repeats within .0001. remove and reinstall the tool holder and it can be .0004
  #12   Ban this user!
Old 02-11-2008, 09:59 AM
thanks vern, that is exactly what I am seeing.
mark
Haas Renishaw Probe Tazzer Haas Mills 17 07-06-2009 06:18 PM
Renishaw Wireless Probe Question HelicopterJohn Haas Mills 9 01-11-2008 09:47 PM
Renishaw Wireless Probe on TM-1P HelicopterJohn Haas Mills 24 11-22-2007 05:54 AM
Renishaw Probe on Haas VF-1 gromit68 Haas Mills 2 07-15-2007 09:04 AM
Mp7 Renishaw probe Cncjunkie CNC Machining Centers 5 02-02-2006 09:13 AM
