Results 1 to 7 of 7
Thread: Going to be Replacing Windows & Way Covers Wipers on my VF3 Any Tips?
    Aug 2007
    Hey guys,
    I am going to be replacing our (front)windows on the VF3 and Way cover wipers and have ordered everything from Haas including the seals for the windows. Does anyone have any suggestions or tips on doing this, thanks.
    Nov 2007
    what year is your machine?
    Aug 2007
    Sorry I forgot to list that, its a 1998 VF3.
    Nov 2007
    Quote Originally Posted by Rocko1 View Post
    Haas has a special tool for the black molding. Without the tool it is a pain in the XXX. The way cover is easy once they are removed and cleaned.
    Aug 2007
    can this tool be bought and if so how much? Thanks
    Registered serviceman's Avatar
    Apr 2007
    it's all about the technique i never used a tool just a screwdriver wrap the molding around the window cut it long do not cut it til the window is almost all the way in fit the window in try to get 3/4 of the way in and just work the moulding into the door much like doing a convertible back window on old convertibles pain in the ass. you can always get oversized poly carbonate and srew it to the doors and ****can the moulding just drill holes in the sheet metal and glue the oversized glass to the doors.
    REYTECH Machine Service Corp. CNC repair NY, NJ
    http://www.reytechmachine.com
    M_D
    M_D is offline
    May 2004
    It usually helps a lot to lubricate the rubber molding. On other but similar projects we have used a heavy concentration of dishsoap and water, but for the sake of preventing possible issues with the soap getting in the coolant we used coolant on the CNC window molding.
    1. P.N.s for Series 1 CNC way wipers?
      By swarf_rat in forum Bridgeport and Hardinge Mills
      Last Post: 03-22-2007, 11:52 PM
    2. Ballnut wipers
      By Zumba in forum Linear and Rotary Motion
      Last Post: 12-30-2006, 05:24 PM
    3. Replies: 0
      Last Post: 09-29-2006, 02:17 PM
    4. Drafts: Tips for vendors and tips for RFQ writers...
      By InspirationTool in forum Employment Opportunity
      Last Post: 12-20-2005, 09:44 PM
    5. Windows XP or Windows 2000 better with Mach2
      By Beezer in forum Mach Software (ArtSoft software)
      Last Post: 10-18-2004, 11:08 AM
