Its a 95 vf-3 my dc buss voltage seems to be low in the machine diagnostics screen at about 145 it is bleeding off for some reason all the way down to 92 volts I verified that my board that supports the drives is good what else could cause this. |
| Check your incoming voltage and the multi tap transformer in the control. If they do not match the output of the transformer could be too low causing the low buss. If it is good, Disconnect the buss output to the drives and disable the axis in parameters. If the buss is stable after that you have an axis bringing it down. If it still bleeds off then that servo distribution card is going out. On some cards there is a potentiometer labeled A-D. This adjustment pot. sets the output voltage to the motor interface and it will end up on your screen. You want your screen voltage to match your actual DC Buss voltage. Loose Nut. |
| Check the voltage at the Bridge Rectifier located on the servo distribution card( the one with the big capacitors) it should match up with what you see in diognostics, if it does not there is a pot there called A to D, you can adjust that till what you see on the screen and what you have at the rectifier are within a couple of volts, if it keeps bleeding down the capacitors are not holding the charge, and you will probably need to replace the servo distribution card. |
| Nte 22k ohm 2 % 2w 322 2w nte 78463 the resistor on this board goes bad i think its the third from the right below the pots red red orange i think. you can usually see the led light getting dimmer you can change this resistor and fix the board. if you ohm it out or look closely you will probably see cracks in it or that it is getting burned up
__________________ REYTECH Machine Service Corp. CNC repair NY, NJ http://www.reytechmachine.com |
| Help..Stuck at relay ext dc voltage missing but dc voltage OK ? | Dirky | Bridgeport and Hardinge Mills | 24 | 11-27-2007 08:33 AM |
| DC Bus voltage on VF0?? | DomB | Haas Mills | 3 | 03-11-2007 03:14 PM |
| LED Voltage | Mr.Chips | General Electronics Discussion | 3 | 02-03-2007 02:10 PM |
| Max voltage | tekno | PicStep Controllers | 3 | 04-02-2006 06:49 PM |
| Stepper voltage | jdholbrook | Stepper Motors and Drives | 1 | 02-23-2006 11:06 PM |
