Old 01-22-2008, 09:17 AM
createacrawler's Avatar
createacrawler is on a distinguished road
Haas "MiniMill" spindle question
I just purchased a Haas "MiniMill" and after running it for a few days I noticed the spindle getting pretty warm to the touch. Not too hot to touch but enough to wonder if there may be a problem. I'm cutting aluminum with a .500 data flute endmill and the spindle load isn't very high. It's only about 50% on the load meter. Should I be concerned? Is the warm spindle normal? It's been rather cold in the shop I've been running it. About 40 or 50 degrees but I always run a warmup program for a while before running it at any high RPM's. Any help would be greatly appreciated. Thanks.
Old 01-22-2008, 10:51 AM
Loose Nut's Avatar
Loose Nut is on a distinguished road
If you can touch it, it is not overheating.
What is the max RPM of your machine? If your machine has an air/oil mist lubricated spindle it could have excessive oil in the spindle that needs to be purged.
Looked behind the main air regulator, if there is a small regulator with a pressure gage, when the spindle is running this gage should read about 17 psi. This is the air that is used to carry the oil to the spindle.
Loose Nut
Old 01-22-2008, 12:05 PM
The machine has two programs O02020 Warm Up and O02021 Run In.
When the tech installed the machine he should have used the Run In program with the regulator Loose Nut mentions turned up to 30 or more psi to purge oil out of the spindle. Then return it to the 17 for n ormal operation.
If the machine is not used for a day or two or if it is in a cold location ther Warm Up should be run before using the machine; it puts up a warning when you hit cycle start for the first time telling you this.
If the machine has been idle for a couple of weeks the Run In should be done again.
Old 01-24-2008, 06:47 PM
HAAS MM is on a distinguished road
the company i work for just got a mini mill after Christmas and before the tech left after he setup the machine he started the run in program, and every morning i run the warm up program. and so far i havent noticed a warm spindle. but then again i havent really used the machine to its capacity either. we are just using it for small parts for the time being. i think the biggest spindle load i have seen is about 30%.
Old 01-24-2008, 07:28 PM
Thisn is the way to do it I think. All my machines get the Warm Up every morning before starting work. Provided this is done we may get warm spindles but never hot; in addition I have never found any correlation between load and spindle temperature, speed yes but not load.
Old 08-10-2008, 01:23 AM
hoi.le is on a distinguished road
Warm up spindle program at Haas manual
O02020 (Spindle Warm-Up)
S500M3;
G04 P200.;
S1000M3;
G04 P200.;
S2500M3;
G04 P200.;
S5000M3;
G04 P200.;
S7500M3;
G04 P200.;
S10000M3;
G04 P200.;
M30;
anybody can confirm it?
Old 08-10-2008, 01:52 AM
automizer's Avatar
automizer is on a distinguished road
yes that is right. My machine its for 4 days at a time with no use, run only on weekends. I wrote my own warm up that each P code is 300 and at the end it cuts a rosette in the air each arc faster and faster to warm up the ball screws as well.
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 08-10-2008, 06:12 AM
plastibob is on a distinguished road
What does the 002021 Run In program do?
Old 08-10-2008, 09:51 AM
The explanation I was given by the Haas person is that when the spindle is not used for several days all the oil drains down into the lower bearing. If the spindle is run at high speed in this condition it can cause overheating. (I can confirm it does cause overheating.) The Run In program combined with the increased air purge pressure redistributes the oil and removes the excess.
Old 08-12-2008, 02:12 PM
Where can I find that program?
  #11   Ban this user!
Old 08-12-2008, 04:33 PM
With your machine you will have got a floppy or a usb drive, the program is on there; O02021 for Run In, O02020 for Warm Up.
I think you can also find them on the Haas website but I do not know the link.
  #12   Ban this user!
Old 07-06-2009, 12:24 PM
timmydabull is on a distinguished road
S500M3;
G04 P200.;
S1000M3;
G04 P200.;
S2500M3;
G04 P200.;
S5000M3;
G04 P200.;
S7500M3;
G04 P200.;
S10000M3;
G04 P200.;
M30;
our spindle warm up was deleted some time ago,just wrote this code to the control and the machine went thru ther code in 5 seconds,how do you get the dwell in between rpm changes?
thank you
tim
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
Can the Haas do "G54P1" style offsets. Mike Mattera G-Code Programing 5 06-23-2007 05:53 PM
Now I get a "197 C-AXIS COMMANDED IN SPINDLE MODE" ALARM theemudracer Fanuc 14 01-08-2007 12:10 AM
"HACKING" the optional functions on the Haas control? AMCTony Haas Mills 16 12-03-2006 12:28 PM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
