#15
| Hi all, I am new to the mini mill, what are the setting 109-112 in the haas settings pages? There are: 109 warm up time 110 warmup x distance 111 warmup y distance 112 warmup z distance Is there an automated warm up sequence? If yes, how to I start it? I do not see a button. Thanks! |
#16
Ofcourse, this is not the case while shut down, so the oil does accumulate on the lower bearings. So after extended periods of more than a day or so, it is a good idea to get the spindle warm up. I would actually dwell at the speeds for about 5 minutes at a time. The program posted is a good start, can't go wrong with it. Unless the axes have been moving without the spindle turning, there is really not much gain in turning up the air pressure, however. Initially you'll see what seems to be a lot of oil coming out of the spindle; this is normal. After that, all will look and feel normal. Pete
__________________ PCOOL dude... |
#17
Hi Pete, Does the TM-1P have the same oiling system? Also, the warm up program originally supplied ran up to 10K. I modified the 2020 warm up program to only ask for 6K as that is the maximum spindle RPM on my TM-1P. Any thoughts? Thanks in advance for your valued input.
__________________ 2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/ |
#18
#19
| The 2020 program is a generic one for all our machines. We over ride the spindle speed from the front panel to 60% for the 6k machines (or 120% for 12k spindles). Even on the greased spindles doing the warm up is a very good thing. Pete
#20
Hi Pete, Thanks for the input. GREAT Idea. Probably something to put in the manual if it is not already there.
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| Can the Haas do "G54P1" style offsets. | Mike Mattera | G-Code Programing | 5 | 06-23-2007 04:53 PM |
| Now I get a "197 C-AXIS COMMANDED IN SPINDLE MODE" ALARM | theemudracer | Fanuc | 14 | 01-07-2007 11:10 PM |
| "HACKING" the optional functions on the Haas control? | AMCTony | Haas Mills | 16 | 12-03-2006 11:28 AM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
