Old 01-21-2008, 09:22 PM
wddanie is on a distinguished road
replacement windows for VF3 door
What's the cheapest way to replace the door windows on a yr 2000 VF3?
Someone squirted acetone on our while trying to cleanup and they look vandalized now so I need to replace them.
Should I buy them from Haas, or is it alot cheaper to measure them and get the local plastic shop to cut up some Lexan the right size. Does anyone have the dimension handy for the windows?
Thanks in advance for your help.
Doug
Atlanta
Old 01-21-2008, 10:38 PM
Take yours out and take them to a local plastic shop...or buy a sheet of Lexan and cut them yourself. It is simple to work with using a table saw and a saber saw with a sharp coarse tooth blade for curves.
One piece of advice: Do not, repeat DO NOT get convinced to buy the Lexan with the abrasion resistant coating. The coating makes it much more brittle and you have lost a large safety factor.
Old 01-22-2008, 07:43 AM
JoBwan's Avatar
JoBwan is on a distinguished road
wddanie,
Price check the lexan first. Where I am from a sheet of lexan is $286.00 and I have to machine it to fit. I can buy them from HFO for $83.00 per window. My vote is to buy from HFO. Price check first!!!
Just a good ol' boy, never meanin' no harm.
Joe
Old 01-22-2008, 09:07 AM
Thats a nice tip. I would have probably gone with the anti abrasion coating.
Thanks,
Doug
Old 01-22-2008, 09:30 AM
Originally Posted by JoBwan View Post
wddanie,
That is a good point. I guess my view is biased; we buy Lexan a 5 or 10 sheets at a time and get a much better price than that. Also have a GR510 which helps a little bit with the machining.
Door Not Opening WASLYH Fanuc 5 10-31-2007 04:09 PM
Looking to get my foot in the door! Tim Wiltse Employment Opportunity 4 09-17-2007 08:31 AM
Looking To Get Foot In Door GANDY505 Employment Opportunity 0 06-05-2007 12:28 PM
Door interlock? Edster Fadal 9 04-05-2006 06:13 PM
Windows XP or Windows 2000 better with Mach2 Beezer Mach Software (ArtSoft software) 2 10-18-2004 11:08 AM
