#15
| In the latest issue of CNC Machining magazine from Haas they have an article about an outfit making oil field equipment and it mentions they use air through the spindle so it must be okay at least at low speeds.
#17
| I've not seen the Haas TSC seal arrangement, but for through air, you really don't need the seal to seal, because if some air escapes up above, its not going to mess with anything. I wonder if there is a way to 'engage the seal' only when coolant is being used?
#18
![]() If they use a labyrinth seal there should be no problem.
| Sweo spindle drive? new mill dead spindle | Shizzlemah | Fadal | 13 | 12-18-2008 11:11 AM |
| interact 4 spindle drive won't turn on spindle | 0041601 | Bridgeport and Hardinge Mills | 7 | 06-23-2008 05:51 PM |
| Lathe spindle bearings and spindle material | mackeym | General Metal Working Machines | 28 | 08-21-2007 02:49 PM |
| Lathe spindle bearings and spindle material | mackeym | Linear and Rotary Motion | 1 | 08-11-2007 10:53 AM |
| Just had my spindle reground by Spindle Grinding Service! | Edster | Fadal | 30 | 06-16-2006 10:48 PM |
