Old 01-10-2008, 05:31 PM
f1jdm is on a distinguished road
TM1 faults
I have a 2000 TM1, yesterday I was getting a spindle cable fault during operation and machine would shut down, today I'm getting a 146 y limit switch, 165 and 166 zero ret margin too small. When reset it may run 10 parts and it may run 3.
Any suggestions would be appreciated
Old 01-10-2008, 05:54 PM
rickyt is on a distinguished road
do you have any chips down in the limit switch housing on the left side of the casting under the machine table?
Check all the cable connectors for the Y axis and spindle to make sure they are tight; things can rattle loose.
Also check for a sticking limit switch on the Y axis; this can give the zero return margin error if it is gummed up and moves slowly.
Old 01-10-2008, 06:22 PM
Thanks, I will check all connections, on limit switch I have taken it apart and cleaned it.
Faults limit switch TT350 Tormach PCNC 1 09-25-2007 12:51 AM
Options for resetting faults on R2020 mecheng10 Servo Drives 0 05-06-2007 09:02 PM
Servo faults are showing up again bgolash Servo Motors and Drives 5 04-29-2007 12:07 PM
Servo Amp Faults Karl_T Servo Motors and Drives 1 04-04-2007 10:48 PM
VFD drive Faults on series I cnc Bridgeport colin1544 Bridgeport and Hardinge Mills 3 09-22-2006 06:36 PM
