01-12-2008, 09:01 PM
Originally Posted by Donkey Hotey Getting back to Cory's original topic: did anything come of the probe errors? Mine was doing the exact same thing. It had a clear line of sight. It failed once, then worked after that.
I wonder: had it been awhile since you used the probe when you got the error? Could the internal switches have been a little sticky and started working again after bumping into a part once or twice? |
I think I have it narrowed down to two potential culprits:
1) The batteries. I plan to order at least 4 extra so Im not caught with no replacements on hand
2) Line of sight. I'm probing parts that barely come out of the top of my vises. I think the receiver for the probe is mounted far too high on the back of the enclosure. When I visualize a straight line between the receiver, and the probe, I can definitely see that the coolant lines, or even the spindle housing itself could be blocking the LOS.
I don't think it's a programming issue, as I can run the exact same probing cycle 5 times, and have it work 5 times, or fail 5 times, or fail 2/3 of the time, etc. |
