#25
Also for what it's worth, I've found that drives with security software on them don't always work. If you plug the drive into a PC and something pops up, or you see it mount more than 1 drive on the PC, you will probably want to find out how to remove that before the Haas control will be able to use the drive. |
#26
On your list programs screen it will specifically say "press origin before eject". If it doesn't say that, you don't need to worry about it. |
#27
Unless you fry a drive as I did a few days ago and then maybe it should be of concern |
#28
Then you should read my previous post regarding waiting for the light to stop flashing, and you should also look into making sure you discharge any static electricity from your own body before grabbing the USB drive...if it doesn't explicitly say to press origin, then pressing origin won't help it in any way. |
#29
| I did indeed read your previous post and headed your advice , good advice , I was already following but it hasnt helped . I just had another pen drive brick , third one so far . This one is one of the little red HAAS 256k pen drives , I have been using it for aprox one week . It was formatted before use . I very carefuly made sure nothing is selected on the pen drive in list programs and that I have a program in memory selected before pulling the pen drive out, Just like the other two that have died. I also have made sure the activity light is not flashing before pulling the drive out. I am guessing there is a problem with my USB port as three dead pen drives in two weeks is excessive, I am following the reccomended procedure and using a pen drive provided by HAAS. This one just like the other two brings up the need to formatt box in windows when plugged into my desktop now , I click the format button , it appears to format and then gives an error message stating unable to format drive . WHen plugged into the mill it recognizes all of them but will not allow access to any of them or any thing on them, none can be accesed or formatted on any of my desktop computers also. Since there is no need to power the USB port down to remove the pen drive how should I proceed? I have less onboard memory than a floppy and cant continue to sacrifice pen drives . |
#30
| Have you explored using RS232 or ethernet? Having myself already fooled around with floppy disks that did much the same auto-self destruct procedure, I finally went to RS232 on a permanent basis. While technically not as fast a transfer rate as a USB device is capable of, most of the time, hassle with plugging and unplugging takes more time than it should.
#32
| I guess thats possible , the first two died after use with the same mill and desktop, the latest one was not used on that PC , I wanted to eliminate another variable and was using my laptop . My biggest issue is the machine doesnt have any memory to speek of and the 3d files I run are fairly large so its convienint to run them from the USB , I guess I will explore whats needed to run the 100+ feet from the office to the mill or purchase another PC to live by the vf4 |
#33
| panaceabea, There are a number of providers that supply DNC software that will send to 100 or more machines at one time. You could run your whole shop DNC with one PC. ![]() One is Predator DNC
#34
Dear Friend, I want to use the laptop to send the program file to the Akira Seiki machine but the laptop doesn't have the RS232 adapter. I used the "USB to Serial" adapter. From the "USB to Serial" connect into another "Serial to RS232" adapter. From the "Serial to Rs232" adapter to "RS232 to RS232" cable. From the "RS232 to RS232" cable to the Akira Seiki CNC Machine. I can't be able to send the program completely. It send out only 99% and 1% is complete. But when I want to send the output from the Akira Seiki back to the computer and it is okay. I am so sorry if I confuse you. But I really need help on this. I can be reach by either email or cell phone below peter.pham@pthmfg.com or 408-888-6706 I think there is a better way to do this. Please help me out. Thank you so much. Best regards, Peter |
#35
I was never told to do anything special just pop it in and out. recently I have had some erros popping it in, it started happening when the temps got cooler took me for ever to figure it out. it was due to me taking my jacket off in the shop and putting it on the clip board on the machine. so when I put the thumb drive in I do it at a slight left angle so to speak and it shorts the machine software out. when my jacket isnt there I wak from the office which is behind the machine and pop it in. I can pop it in straight or at a slight right angle but if I do it from the front of the machine with my right hand and I am slightly off to the left it shorts and errors out the machine. never did that before. I have that on my list of items to check out when I call the techs over when there not busy along withthe new software. I can also see everyone of my directories on the thumdrive and I run long file names for my programs and I see those as well. I think I am running a 4gig one it may be 2 gigs and I have 3 back ups that I rotate, it has all my office files prints cad drawing files emails etc etc on them. Dont know if I can read any files but I can see the directories and the file names. basically a entire machine shop in my pocket. LMAO, I look at it this way if I ever have a fire in the building I am renting and my shop is to a point I cant run, I can go hit a buddies machine shop and be running in one hour or less. I love those thumb drives. Delw |
| Running Programs from USB thumb drive | HelicopterJohn | Haas Mills | 16 | 11-11-2007 03:52 PM |
| DC motor drive control | jedcam67 | General Electronics Discussion | 3 | 06-03-2007 03:53 PM |
| Fanuc axis drive control PCB- S Series | M.RISHIKESH | Fanuc | 0 | 12-04-2006 10:25 AM |
| Reconfiguring Yaskawa Drive for Position Control? | rpseguin | Servo Motors and Drives | 13 | 10-31-2006 07:09 PM |
| USB Thumb Drive Software | automizer | General CAM Discussion | 6 | 12-29-2005 12:14 PM |
