Would someone who has a vf1 or 2 mind measuring the height of the ceiling. Floor to highest point. I have 106 inches and hope that is enough. The dimensions say 104.50 inches but I dont think that takes into consideration the leveling pads so I dont know how much additional height I need. Thanks Mark |
| I don't care how many threads you start butcha' coulda' just posted the question in the other thread. ![]() 104.5" sounds about right. I can get you an exact number if you need it. Mine pokes up just beyond the ceiling joists (the spindle is right between a pair of them). The joists are at 99" and the spindle & cable track run up between them another 4-6" during tool change. I can start it up and get you an exact number tomorrow. Is your ceiling drywalled? Limited by a second floor? If there's nothing above it, you could cut a rectangle through the drywall (between joists) and just make sure the machine is centered under the hole. The part that pokes up is just the width of the spindle sheetmetal and really, it's just the 6" cable guide using up the height.
__________________ Greg |
| Thanks greg, it didnt even occur to me to do that. I have a dry walled ceiling 2nd floor above. I have 97 inches to the drywall ceiling and another 9 inches to the bottom of the second story floor (in between the floor joists). Also if you woulnt mind measuring from the floor to the top of the enclosure while you are in measuring mode I would really appreciate it. The dimension on the Haas site are not that complete. How much room did you leave behind your machine (between the machine and the wall) |
| Checked mine this morning. 103" to the top of the metal guards around the Spindle and 108" to the top of the black flex cord. Its also up about 1" off the leveling pads so you could lower is down a little. I left two feet from the back wall and three feet from the side wall. Hope this helps. |
| The door on the back of the machine is 36" and it's supposed to have enough room to open fully. Mine isn't against a wall. It's in the center of the floor and the operator side faces the back wall. I have all of my machines in the center of the floor like that, in a row with their backside facing toward the doors. I park motorcycles up against the back of the machines. That leaves service access to all of them. As for the height: yeah, that's gonna' be tight. I'll measure it when things warm up a bit.
| Yes, as slatern44 says, 108 inches to the top of the cable carrier when the spindle is at maximum height in a tool change.
That was the type I measured. The Side Mount extends up the side of the spindle to slightly higher than 8 feet and makes things so wide it may not be possible to fit between the ceiling joists. How about your door clearance for getting it in?
#11
| I wanted the SM changer but I guess there are enough trade-offs between the two designs that I think it was a draw (oversize tools, heavy tools, etc).
#12
| Mark, If you've got 108" I'd say you're okay with the height. I'm not so sure on the width. The leveling feet on mine are at the lowest setting. To the best of where I can measure it looks like 103-104" at the cable guide. The highest point is not the spindle sheetmetal (although that also protrudes above 100"). The widest point of the sheetmetal around the spindle that would protrude above the studs is 16.5". That might be a problem for you if you have the second floor above. I don't know what the stud spacing is for a load-bearing floor but I'm guessing 16" on center. The top of the main cabinet (the coolant enclosure) is 69" tall. The arm that supports the control pendant sticks up above that about 4-5 more inches (depending on where you measure). It might be worth a trip to either the HFO in Torrance or the showroom in Oxnard. Bring a copy of the machine outline in their brochure and a tape measure. Measure everything you think you'll need. That's what I did. When they delivered it, I had tape lines on the ground for exactly where the machine had to go. It was spot-on.
| return height | shepherd | BobCad-Cam | 7 | 06-20-2007 01:08 PM |
| height adjustment on a ........... | hoodsie65 | General Metal Working Machines | 0 | 02-04-2007 03:55 PM |
| Torch Height Control / Capacitive Height Control | ahlbebuck | Open Source Controller Boards | 0 | 11-27-2006 02:32 PM |
| non ARC height sensor | sunmix | General Electronics Discussion | 1 | 11-05-2006 12:51 PM |
| text height | 47MLB | Mach Software (ArtSoft software) | 1 | 03-16-2005 06:34 PM |
