  #13   Ban this user!
Old 12-28-2007, 07:36 AM
serviceman's Avatar
serviceman is on a distinguished road
always follow what is printed on the way lube tank there are not many machines out there that take dte 25 they used it for a little while and then they went back to vactra 2 on the way lube tank it will say what oil to use vactra or dte
REYTECH Machine Service Corp. CNC repair NY, NJ
http://www.reytechmachine.com
  #14   Ban this user!
Old 12-28-2007, 08:28 AM
JACKOFTRADES is on a distinguished road
Whatever was printed on the side of the waylube tank has been worn off.
  #15   Ban this user!
Old 12-28-2007, 12:41 PM
serviceman's Avatar
i would go with vactra 2 or equivalent or call haas
  #16   Ban this user!
Old 12-31-2007, 07:17 AM
The Haas service tech said to use VAC 2. I also did a spindle lubricater test the 50 taper spindle should get 1.7 to 2.1 cc every 4 hours. The new spindle is in and we are ready to go 7000 dollars later.
  #17   Ban this user!
Old 03-01-2008, 11:25 PM
sixstring is on a distinguished road
HAAS SPINDLES
MY COMPANY HAS A VF-3 AND A VF-6 , THE OLDEST BEING ONLY 3 YEARS .BETWEEN THE BOTH OF THESE MACHINES THEY HAVE HAD 9 SPINDLES REPLACEMENTS IN THIS TIME FRAME. YOU CAN'T SEEM TO RUN THESE AT MAX R.P.M. FOR ANY DURATION WITHOUT COOKING THEM.THE HAAS SPINDLE PROBLEMS SEEM TO BE AN ONGOING ISSUE. WE FINALLY GOT SICK OF THE PROBLEM AND BOUGHT A FADAL 4020 WITH A HIGH SPEED SPINDLE TO RUN A LONG CYCLE TIME ALUMINUM JOB THAT WAS ROACHING THE HAAS SPINDLES.WHEN THE JOB WAS ON THE HAAS ,THE NOISE FROM THE SPINDLE WAS SO LOUD THAT EVERYBODY IN THE SHOP WERE WEARING SHOOTERS MUFFS!!! CAN'T EVEN TELL THE MACHINE IS RUNNING WHEN USING THE FADAL.BEEN RUNNING FOR 6 MONTHS ON FADAL WITH NO ISSUES AT ALL. WHEN THE DEALER WE BOUGHT OUR 4 HAAS MACHINES FROM FOUND OUT WE WERE GOING TO FADAL THEY GOT REALLY PISSED OFF AND STARTED NIT PICKING OUR WARRANTIES AND SERVICE.NEEDLESS TO SAY WE WON'T BE BUYING ANYMORE HAAS MACHINES.HAAS SHOULD STOP GOING FOR QUANTITY AND GO BACK TO QUALITY !!!!!!
TOOLMAKER
  #18   Ban this user!
Old 03-03-2008, 04:22 PM
swartling is on a distinguished road
Way lube 68 and mobil vactra #2 are the same lubricant chemically. Mobil DTE 25 is like Super Hydraulic oil 32 which IS lighter than WL 69 on MV 2. We have used WL 68 in our VF 6 since we have had it. (1995)
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 02:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
spindle motor Yint Mechanical Calculations/Engineering Design 0 10-13-2006 09:35 AM
AC or DC as spindle motor? svenakela General Electronics Discussion 0 10-06-2005 04:02 AM
Spindle motor TommyB DIY-CNC Router Table Machines 1 12-08-2004 10:11 AM
